Old Feb 23, 2012, 12:29 AM
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Originally Posted by JONBOYLEMON View Post
Heavier than I thought it would be.
Anxious to hear report.
With a raw airframe component weight of 185g (wing, fuse, tails), I figure the ball-park typical ready to fly weight should be:
Airframe components: 185g
Horns, blade, pushrods & control sys., hardware, etc.: 10g
Battery, regulator, Rx, switchjack: 45g
4 servos (2-285, 2-DS09): 33g
Glue, balance weight, misc.: 7g
TOTAL: 280g (depending on where you like the CG)
Alan, sounds like yours is spot on. 281g (9.9oz) should be a good base weight for that wing to do what it does best.
like.2.fly is online now Find More Posts by like.2.fly
Old Feb 23, 2012, 01:00 AM
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
Alan, do not think that parking lot lighting is light enough for a maiden....... Oh yeah, it seems real light until you get above 50' or so and then its night time again.......
So yeah wait till; that ball of fire is doin its job.
1st thing in the morning in dead air will be perfect for maiden, but probably not what she was made for, will let you know how she floats and runs though! Yeah, I am as excited as you are!!!!!
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Feb 23, 2012, 03:16 AM
Joined Aug 2009
hi, empty i'm at 74mm from LE (i heard people flying it at 78mm) ,when it get's turbulent/windy i prefer 68-69mm , but that's a personnaal choise , i like to have it very far forward.
using d47's on rudder and elevator and a 30-35gr pack you get a a.u.w.of about 265grams with the glass tails, with carbon veil ones and a small battery you can get as low as 250grams with that lay-up
enjoy the maiden!
-kristof-
krikkens is offline Find More Posts by krikkens
Old Feb 23, 2012, 07:44 AM
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
280g is a perfect weight. And you wont have any issues with dead air at that weight. If you move the CG back to 73-74, you should easily be able to get into the 270's AUW. In calm air, 70mm CG may feel a bit too far forward because it will have a tendancy to not want to slow down to a good float speed unless you put in a good amount of camber, 10-15mm. At the 73-74 setting it handles calm air wonderfully with the recommended float camber. In turbulence, the 70mm setting is perfect. Keeps the nose down and the speed up.
Try it out and let us know what you think!
Wave Glider is online now Find More Posts by Wave Glider
Latest blog entry: Helios and XXLite DLG
Old Feb 23, 2012, 09:05 AM
Thermal, where art thou?
BavarianCharles's Avatar
85045
Joined Oct 2005
Originally Posted by Alan C View Post
Yeah it's a little heavier than I had hoped. Not sure where I can cut weight. Ill loose weight if i move the cg back to where Kyle likes his. I'm not to worried about it. My blaster is around 290g and it still floats with the best of them.
It's going to be hard to sleep tonight.
Alan,
even if you don't have it fully trimmed, please bring the Helios to the AZ Open. I'm probably not the only one who's curious, and there should be plenty of time left Saturday afternoon to get it ready for Sunday.
BavarianCharles is offline Find More Posts by BavarianCharles
Old Feb 23, 2012, 10:40 AM
are we there yet?
Alan C's Avatar
USA, AZ, Surprise
Joined May 2004
I'm at a customer so I don't have much time to post but for now let's leave it at I Love The Helios! Even with the cg at 70 it flys great. I'll post more later.
Alan C is offline Find More Posts by Alan C
Old Feb 23, 2012, 10:53 AM
NCDLG's Avatar
United States, NC, Raleigh
Joined Sep 2010
picture of the machine
NCDLG is offline Find More Posts by NCDLG
Old Feb 23, 2012, 10:56 AM
are we there yet?
Alan C's Avatar
USA, AZ, Surprise
Joined May 2004
That looks hot! I like the tail paint scheme.
Old Feb 23, 2012, 11:02 AM
American Exile
Germany, BB, Nauen
Joined Jan 2009
I wish my Helios was here!
xbted is offline Find More Posts by xbted
Old Feb 23, 2012, 11:47 AM
are we there yet?
Alan C's Avatar
USA, AZ, Surprise
Joined May 2004
Originally Posted by BavarianCharles View Post
Alan,
Yes I will have the Helios at the AZ Open and will be flying it in the contest.
Old Feb 24, 2012, 07:52 AM
pyrsly's Avatar
Poland, Śląskie, częstochowski
Joined May 2008
hihi how is the STF fin working?
pyrsly is offline Find More Posts by pyrsly
Old Feb 24, 2012, 08:12 AM
NCDLG's Avatar
Joined Sep 2010
Hey Sebastian, Love the Verticals you make. I've been flying it on the Akcent2 for some time now. It makes that DLG so much better.
Keep up the great work!
Eric
Old Feb 24, 2012, 07:02 PM
are we there yet?
Alan C's Avatar
USA, AZ, Surprise
Joined May 2004
Does anyone fly the Helios with aileron differential? I like the way it flys with symmetrical throws, just curious.
Kyle your right the cg @ 73mm is perfect. Flys well, indicates lift and really slows down in thermal mode to climb.
Alan
Old Feb 24, 2012, 11:05 PM
Kyle Clayton
Joined Feb 2008
Glad you like it Alan, go kick some AZ butt with this thing!
Old Feb 25, 2012, 04:58 PM
Beetle-Jet's Avatar
Joined May 2010
Alan
Hi,
You can take it even farther back to 75mm and it still fly grate
my setup
Beetle-Jet is offline Find More Posts by Beetle-Jet
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 07:07 PM
Sold Hyperion Helios 63 size Pattern Plane , Scorpion powered ,lpu socal Dennis Everett Aircraft - Electric - Airplanes (FS/W) 3 Dec 29, 2010 12:19 PM
Found 40" DLG apogee xray fireworks homebrew RCDC Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 02:14 PM
Discussion Homebrew DLG Launch Problems Sail Aire Hand Launch 11 Aug 24, 2006 09:42 PM
Build Log Homebrew Mini DLG Build Hutch Hand Launch 46 Nov 23, 2004 08:59 AM
