Old Nov 22, 2005, 01:38 AM
matt the cat
strongsville ohio
Joined Oct 2005
pics of my trexs!give me your thoughts?
here a few of ny trexs i threw toghther. let me know what you guys think?? they both fly well. but some sugg from you guys would be great![IMG]mg[/IMG]
matthew james is offline Find More Posts by matthew james
Old Nov 22, 2005, 01:45 AM
Yayyy
Joined Nov 2004
They look terrible! Send them both to me immediately so I can dispose of them for you
chuckyteets is offline Find More Posts by chuckyteets
Old Nov 22, 2005, 01:49 AM
matt the cat
strongsville ohio
Joined Oct 2005
one of them i am using the warp 4 -4 turn and the other the aling motor both 35 esc fether 55 on one the other 6 gram bb gws.both cf boom hor and vert .and bling in both of them here and there . wondering what other bling i should add to improve flight performance? thanks guys matt james
Old Nov 22, 2005, 01:50 AM
matt the cat
strongsville ohio
Joined Oct 2005
your funny chuck ha ha!!
Old Nov 22, 2005, 02:17 AM
Trex450/500/600E(vBar)
rotarypower3's Avatar
Melbourne (east burbs), AUSTRALIA
Joined Mar 2005
The blue one has got the tail blades on backwards.
rotarypower3 is offline Find More Posts by rotarypower3
Old Nov 22, 2005, 02:33 AM
matt the cat
strongsville ohio
Joined Oct 2005
you are right rotary power problem has been corrected!! see i did not even notice that thank you !!
Old Nov 22, 2005, 02:54 AM
NO NO come back...spLAT!!
United States, CA, Anaheim
Joined Sep 2005
-if you are a beginner and learning to hover on hard surfaces, then it's better if you leave those blue rubber cushion on the skids off. when the heli drifts sideway, they tend to grab the surface causing heli to tip over. if you fly on grass then no difference on or off.
-the red heli, if tail doesn't hold then you might have to rotate gyro 90 deg. I haven't seen a set up w/gyro facing sideway. not sure.
-you'll find the blue one to have tail slop, it's because of the plastic tail servo mounts. They dont provide a stiff platform and so when your servo respond to the gyro, it moves back and forth. Worst, it can break the plastic case on servo, like mine.
kryptoniteRxn is offline Find More Posts by kryptoniteRxn
Old Nov 22, 2005, 02:59 AM
matt the cat
strongsville ohio
Joined Oct 2005
ya ya !! they do man you are right! just took them off!! these thinks you guys are telling me are great tips i have been hovering in my basement on ceramic tile surface and yes! they do tend to grab!! thanks kryptoniterxn! god bless1 matt
Old Nov 22, 2005, 03:03 AM
I'll Mace You Good!!!
stevenkelby's Avatar
Adelaide, Australia
Joined Sep 2004
That's how all the cool people have their tail blades!
Wish I had 2 Trexes Matthew, then I could race them.
stevenkelby is offline Find More Posts by stevenkelby
Old Nov 22, 2005, 03:05 AM
Yayyy
Joined Nov 2004
Friggin' awesome.
Old Nov 22, 2005, 03:12 AM
matt the cat
strongsville ohio
Joined Oct 2005
well i came into some extra money that i had and fig what the heck! and well, here they are. kryptoniterxn, red heil seems pretty rock solid! blue one seems to have the problem you speek of? should i have gyro set at 75% ?that is where it is now.i am ordering the metal mounts for the tail servo now!! thank my friend! matt
Old Nov 22, 2005, 03:22 AM
matt the cat
strongsville ohio
Joined Oct 2005
Old Nov 22, 2005, 03:23 AM
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
Not to sound finicky but the belt on the Red TREX looks loose!
Nice pair o' Rex's though...
RMihara is offline Find More Posts by RMihara
Old Nov 22, 2005, 03:24 AM
Joined Oct 2005
Those blue landing struts have been known to fracture. Mine did. Luckly ir had not flown. A stress fracture developed around the mounting hole. Beware. John
john_miln is offline Find More Posts by john_miln
Old Nov 22, 2005, 03:31 AM
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Originally Posted by kryptoniteRxn
...the red heli, if tail doesn't hold then you might have to rotate gyro 90 deg. I haven't seen a set up w/gyro facing sideway. not sure...
Actually, if you think about it some more, the rotational sensing axis is about a line which extends vertically about the gyros case. So, it really wouldn't matter on the orientation of the gyro's case-relative to the heli.
What does make a difference is the location of the gyro-relative to the heli's main mast. The farther away the gyro is located from that mast, the less sensitive it is to changes in yaw.
Idea Sombody flying the IMA Twin Otter - Give me your opinion anyway!! Ben_E Foamies (Kits) 2 Jul 23, 2009 08:32 AM
Cool hummingbird will the himax brushless work can you guys give me your in put breyman Micro Helis 1 Sep 06, 2005 10:13 PM
Alert Please take a look at this and give me your Honest Opinion Starguard Parkflyers 5 Jul 25, 2004 12:29 AM
