Old Oct 12, 2014, 07:34 AM
United States, OK, Altus
Joined Jan 2014
Help!
Servo for the hobbyking 1400mm sbach
I am buying the 1400mm sbach from hobbyking. I've read that the 9g aileron servos strip easy. Can some please tell me what size servo works? Will any micro servo fit? What's the best servo choice? I am leaning toward hitec, what have you upgraded to?
RCreaper is offline Find More Posts by RCreaper
Old Oct 12, 2014, 10:31 AM
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
The answers you seek lie here.
Also if you scroll down you will see the dedicated forum for the hk 1400 sbach. Rcg has a great search tool also.
mcnowhere is offline Find More Posts by mcnowhere
Old Oct 12, 2014, 01:42 PM
Joined Jan 2014
Lol. Yeah I searched and found a topic with 100 plus pages. After go through multiple pages I gave up.
Old Oct 12, 2014, 11:37 PM
Sydney Australia
Joined Feb 2002
S bach 340 servos
Most folk stay with the stock servos until they give trouble. Then fit hitec HS82mg or similair
The best and quick way to search, select thread, click Thread Tools >show attatchments (top rt.)
Click to open picture.
Click View Post (Bottom of picture).
Hope this helps
hi flyer is offline Find More Posts by hi flyer
Old Oct 12, 2014, 11:51 PM
Joined Jan 2014
will the hs82 fit for ailerons? There dimensions is 30x30x12. I thought stock servos were something like 22x12x26 or something close
Old Oct 13, 2014, 01:50 AM
Sydney Australia
Joined Feb 2002
Wing servo cut outs
The stock wing foam servo cutouts may require just 2 or 3 mm. of foam removal ,across the wing,for HS82mg fit.
For your info. the mods that must be done to make this bird more durable, and airworthy.
Spinner,replace with Dubro .Stock spinner out of balance and hard to balance.
Fit a UBEC of switch mode type, dont trust stock one.
Tail wheel replace with Dubro or similair.
Cooling ,increase diameter of holes in foam at rear of cowl. a 70W. hot solder iron ok for this mod.
A larger air exit hole on belly of fuse.
Ensure good retention of canopy.
Consider fiberglass reinforcement of fuse landing gear area.
Check motor mount for security , may require a bead of epoxy glue.
Elavators , reinforcement, carbon fiber rod recessed into foam leading edge across both halves.
Fuse, reinforcement, carbon fiber rod or tube 3 or 4 mm. diam ,from fire wall to rear of canopy and just below canopy ,both sides.
Discussion NEW SBACH 342 EPO 1400mm from hobbyking stalyoni 3D Foamies 2360 Dec 04, 2014 05:54 PM
Question Hobbyking 1400mm Sbach 342 or Parkflyers 49" Sbach 342 RCreaper Electric Plane Talk 4 Oct 11, 2014 06:20 PM
For Sale Sbach - HobbyKing 1400mm EPO Flying Sqwerl Aircraft - Electric - Airplanes (FS/W) 2 Jul 10, 2014 08:02 PM
Sold Hobbyking EPO 1400mm (55") Sbach - $120 - LPU - Long Island, NY ChrisNYPilot Aircraft - Electric - Airplanes (FS/W) 0 Nov 22, 2013 10:47 AM
Video Some SUPER HobbyKing.com 1400mm Sbach Fun!! teknokraze Electric Plane Talk 0 Apr 26, 2012 08:16 PM
