Old Oct 26, 2013, 08:45 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Go to the park, he might be there. They don't have a current entry list but I found him in some past race results.
Ron Olson is offline Find More Posts by Ron Olson
Old Oct 26, 2013, 03:59 PM
BAH MINI H 4 Life
632bigduke's Avatar
Joined Sep 2013
Help from experienced Boatmen!!
6717 is the prop number . If you take a pic of it standing blades up I cant tell you what's Ben done to it but can tell you pitch . Most 6717 are 3/495 .
632bigduke is offline Find More Posts by 632bigduke
Old Oct 26, 2013, 04:03 PM
BAH MINI H 4 Life
632bigduke's Avatar
Joined Sep 2013
If you try another prop get Brent or Bob Austin to fix you a 7022 or Bob English to fix a voodoo cat prop , they Swear by that voodoo prop but I can tell you now 7022 for racing from Pww Brent daily will give em hell!!! Lolo
Old Nov 03, 2013, 08:26 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
So, what's the latest? Got it wet yet?
Old Nov 03, 2013, 11:59 AM
F3NIX1's Avatar
Joined Jan 2013
Lmao!! Not yet. I need to get a reciever to use with it. I do have a question for you... I have the new spektrum 4 channel radio with the dsmr. I havent had any issues with range on land, but the boat is obviously a bigger concern. A little harder to get to if it does go out of range. I also have a Ko Proko helios. What do u think I should do? I would need to buy a receiver for either if I use them. Which way should I go?? Or should I just breakdown and get a new reciever??
F3NIX1 is offline Find More Posts by F3NIX1
Old Nov 03, 2013, 01:13 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
If you're going to use the Spektrum then get the Marine RX. I've driven my buddies boat with that in it and it works great. I've seen the regular RX's lose signal in under 100 feet on the water.
Old Nov 04, 2013, 08:06 PM
Detroit
Joined Aug 2006
agree 100% with Ron. When you get into short wavelength stuff like DSM/2.4 GHz, you really have to start worrying about attenuation and multipath from things like reflections off of the surface of the water. Marine DSM receivers generally have two antennas, one you orient vertically like any other antenna, and one you have positioned horizontally. The Rx then has two signals to compare in order to make sure it's getting valid commands. Car/plane Rxs usually only have one tiny antenna wire sticking out of the Rx and I would never use one on a boat.
In the 4 years I've been running Spektrum DSM radios, I've not once had a radio problem. The nice thing about digital receivers is that they're basically one chip and a handful of resistors and capacitors, there's no potentiometers to freak out at the slightest bit of humidity. as far as I'm concerned, AM and FM radio systems belong in the dustbin.
jz78817 is offline Find More Posts by jz78817
Old Nov 11, 2013, 05:51 AM
BAH MINI H 4 Life
632bigduke's Avatar
Joined Sep 2013
I've always wanted to try a spectrum on water but when I got started I'm boats I got a 3pm fasst futaba with a fs603 and the fasst antenna and running SAW I've stretched the legs a LOONNGG WAY lol
Old Nov 11, 2013, 09:18 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
I don't really know how to describe it, when driving my buddies Sprint Cat using the Spektrum radio with the Marine RX, I've never felt more connected to a boat. I told him that if he ever sells the radio I want it!
Old Nov 11, 2013, 11:51 AM
F3NIX1's Avatar
Joined Jan 2013
I should be getting my receiver any day now....im jonesing to get out to the lake!! I bought the 3 channel marine reciever. Stay tuned for my next update!!
Question Moved to correct forum F3NIX1 Racing Boats - Electric 0 Oct 01, 2013 09:28 PM
Help! Help from experienced boaters, please! savage0102 Racing Boats - Electric 5 Sep 10, 2013 11:09 AM
Discussion Recommendation Required from experienced EDF gury Static EDF Micro EDF Jets and Power Systems 5 Feb 07, 2013 12:50 PM
Discussion Help needed from "experienced" modelers!! gwinhh Fuel Plane Talk 4 Dec 08, 2006 01:56 AM
Help from some experienced flyers, please. sarge High Performance 14 Apr 18, 2005 01:51 AM
