Old May 31, 2014, 11:22 AM
Joined Oct 2011
How about a Turnigy MAX 80W?
Been watching this with interest - I have a Turnigy MAX 80W which also has a 3 pin USB/Temp socket - I have connected this up (-ve and signal) but don't get any reading at all - I wired this to a 9 pin D socket and plugged this into my RS232/USB converter (gives me a 'virtual' serial port) but get nothing, via Logview or Putty (yes, I have USB enabled on the charger) I put a multimeter on the -ve and signal but get no reading at all - even when there is a battery being charged.
So I pulled the cover off the charger and took a couple of photos, but was not sure if I had anything missing or not. Couldn't see any missing components, if anyone has any advice I would appreciate it?
Chris
cparsons is offline Find More Posts by cparsons
Old Jun 06, 2014, 10:11 AM
adioperator's Avatar
Joined May 2010
Originally Posted by willy163 View Post
This APP seems to be specific for Digitech QM1576 multimeter.
Communication protocol is certainly different, so impossible to use with our charger.
Willy.
Has anyone tried this app https://play.google.com/store/apps/d...rc.chargemaste ?
adioperator is offline Find More Posts by adioperator
Old Jun 07, 2014, 03:28 AM
willy163's Avatar
Italia, Piemonte, Strambino
Joined Feb 2010
Originally Posted by adioperator View Post
Maybe it can work! The only trick to do is to connect a serial bluetooth module to the charger.
I'm finishing to build my home so I can't try before a couple of months.
Willy.
willy163 is offline Find More Posts by willy163
Old Jun 07, 2014, 04:21 AM
Joined Jun 2014
Hi Chris,
If I understand this thread correctly and your charger is of the "breed" being discussed here, there would be a couple of things for you to look into. Firstly according to the first post in this thread, by Marek, "Output signal is 5V-TTL RS232, to connect to PC serial port you'll need level shifter". So the voltages aren't conforming to the RS232 standard and this suggests to me that the RS232/USB converter won't work for you. Marek provides a couple of links and others on recent pages have found "TTL to USB converters" via ebay to do this (gernerally costing just a few dollars).
The lack of signal on your multimeter is probably explained by some missing parts from the other side of the PCB to that which you posted pictures for. (That is to say, missing from the non screen or display side of the board). See pic below, (not mine), which I believe shows the "play it safe" option.
Marek wrote:
"The pin that can output serial data isn't routed to the 3-pin connector anymore. It goes directly to the usb interface circuit, but the circuit isn't there. That's why LogView won't work out of the box. All you need to do now, is to get the signal routed back to the 3-pin connector and you can enjoy LogView curves.
To play it safe you will need a 10k 0805 resistor, a 100k 0805 resistor and a 1n4144 mini-MELF diode and a piece of wire. This way the serial output is 100% safe if you plug in the temp probe and forget to change menu setting. See photo for where to put these components.
To play it dirty you just need a piece of wire, connect the left pad of where the 10k resistor is in the photo with the middle pin of the 3-pin connector. Voila.
I'm awaiting a USB to TTL converter myself, but have improvised and put (a non surface mount component version of) the "play it safe" components on the board of my Accucell 6 and can see a 0 to -5V waveform appear on my antiquated oscilloscope, so things look promising.
Hope this helps!
Nigel
P.S. I used to be able to see the images from the post by Merek on page 1 but Internet explorer just shows a broken link icon. I notice there is a pic showing the "dirty job" option by MatadorAV8 on page 1 for those wanting that option, which will be a problem if you connect a temperature sensor as I understand it; presumably something will die!
Nige333 is offline Find More Posts by Nige333
Old Jun 29, 2014, 07:34 PM
SteLee's Avatar
Joined Jun 2014
Originally Posted by pszynk View Post
I think the scheme should rather look at the ways.
Regards
Not to be disagreeable, but I made this one and it works perfectly. I also had to change the 39k resistor in the charger that is far to large for what it has to do, with a 1k resistor.
If you change that resistor, the temp will drop a little (3 degrees). I just lowered my cut-off temp by 3 degrees.
SteLee is offline Find More Posts by SteLee
Old Jun 30, 2014, 02:18 AM
willy163's Avatar
Joined Feb 2010
Hallo.
Thanks for sharing. Since it is inverting, do you connect it directly to a RS-232 port without a level shifter (like MAX232)?
The 39k resistor you've repleaced is the one on the transistor base? Did you try with 10k? Maybe it works ant it doesn't hurt temp reading.
Willy.
Old Jun 30, 2014, 09:13 AM
SteLee's Avatar
Joined Jun 2014
Hallo right back at'cha.
Yes, as the labels and description imply, this connects directly to an actual RS-232 port. Almost all the rs-232 ports I've dealt with will accept a 5 volt signal as long as it's inverted like what a 1488 or Max232 chip does.
Regarding the 1k vs 10k resistor... I'd rather change the setting in the charger than have to solder several surface mount resistors the size of a flake of pepper in order to find the one with the optimum value. B-) Feel free to give it a try. I suppose the right tools would help.
I hope that didn't sound snarky.
Update: I've just tested going from an atmel AtTiny4313's USART port powered by about 4volts (1s Li-ion battery) at 9600 baud, to an RS-232 port, and it works perfectly.
SteLee
Old Jun 30, 2014, 09:20 AM
willy163's Avatar
Joined Feb 2010
Old Jun 30, 2014, 11:28 AM
SteLee's Avatar
Joined Jun 2014
Hugh P wrote:
"This may be of some help decoding the 4 button chargers
You can download the program that he wrote while decoding the data block at
http://www.quincyhobby.com in the download tab."
Hi.
Have you used that program "USBCharger3000" that you posted about?
I had problems with the .ini file making the program report something like "ComCOM2 not present". So I manually edited it to say "2" instead of "COM2". Now it just doesn't work. Any Ideas? Do you know how to contact the author? I couldn't find any contact info, other than a mailing/physical address. 8-(
Update:
In case anyone else is interested. I contacted the author and they are looking into these problems. Possible update I hope.
Tnx
Stephen
Old Jul 01, 2014, 05:08 AM
Joined Oct 2011
Originally Posted by Nige333 View Post
Hi Chris,
Hope this helps!
Nigel
Thanks Nigel - I was missing the image and now I have seen this I'll take the PCB out of the case and have a look at the underside - I am sure I can find a couple of small resistors and a diode
Regards
Chris
Discussion Need Help with turnigy accucell 6 HeliStyle Batteries and Chargers 22 Sep 23, 2012 12:52 PM
Found Turnigy Accucell 6 cell Lipo Charger/Balancer Draven Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 29, 2009 08:02 PM
Question Turnigy Accucell-6 from HobbyCity Bookstar75 Batteries and Chargers 4 Mar 25, 2009 10:04 PM
Discussion Turnigy Accucell-6 Question LipSanFlip Batteries and Chargers 7 Feb 05, 2009 04:42 PM
Discussion will the turnigy accucell 6 charge a123 cells? HeliStyle Batteries and Chargers 3 Jan 05, 2009 05:44 AM
