Old May 08, 2010, 01:54 AM
sarabi's Avatar
sky
Joined Nov 2009
my home made quadrotor is ustabled .help me
Hi
I know that you know about the detail of quad rotor.
I have big problem with my quad rotor. It would be better to explain my problem.
My program and my equipment cannot modify the less than 5 degree angle. When my quad rotor tilt to
Roll to 5 degree angle it does not modify that.and when the angel become the 6 degree the controller Throw its to other side rapidly .and the quadrotor is unstabled.
My equipment’s are:
ESC: CASTEL creation 35
Motor: Motrolfly
Prop: 12*4.5
Control loop Frequency: 25 Hz
Accuracy of AHRS: 0.1 degree
Would you tell me my problem?
Another question : How can I use the 500 Hz write to motors with my Esc`s?
Castel creation says that their ESC `s has the 11 bit resolution or 2048 step .with 500 Hz frequency for write the motors. How can I check it?
sarabi is offline Find More Posts by sarabi
Old May 08, 2010, 10:35 AM
Joined Jun 2009
have your control board output data over serial to a terminal, you're probably having precision issues.
Also, 25 Hz PID loop is way too slow for a small quad. You need at least 100 Hz to even approach any resemblance of stability.
tori3 is offline Find More Posts by tori3
Old May 09, 2010, 04:27 AM
sarabi's Avatar
sky
Joined Nov 2009
How can i increase the PID loop frequency?
my first AHRS gives me 25 - 50 Hz frequency .
I think i must use the AHRS ,that gives me 100 or 200 HZ update rate.
Mini-HowTo My home-made Dynamax/Big Screamer combo Knife Liddle Electric Ducted Fan Jet Talk 62 Jul 19, 2010 09:58 AM
Discussion my 1st two home made plane's and plan for F3p bedlam Indoor Pattern/F3P 9 May 15, 2010 05:23 PM
Discussion Trex 450 - made it to stable, help me spice it up... albireo Mini Helis 3 Apr 09, 2010 02:24 AM
Discussion Home made Me 109 1:10 with retract akivon Electric Warbirds 21 Feb 23, 2010 01:32 AM
