Old Jul 21, 2007, 08:55 AM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
Question
Arming Switch Question
Guys,
I am just getting started in electrics and I have a question about how people are doing their arming switches. Having flown gliders for my entire time I have flown RC I get a little nervous around the business end of these electrics. Not sure if the power system makes a difference on how you do the arming switch so I will describe the two systems I am currently using.
System 1:
Motor: Neu 1105-2.5Y/4.41
Controller: Phoenix 35
Battery: TP2100 3S Prolite
System 2:
Motor: Neu 1112-1.5D
Controller: Phoenix 80
Battery: TP3300 3S
Any help you guys can give will be greatly appreciated.
Thank you,
Pat McCleave
Wichita, KS
pmccleave is offline Find More Posts by pmccleave
Old Jul 21, 2007, 03:53 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I've only got an arming switch on one of my models, and that's because access to the battery connection is too close to the prop for comfort. I put a 4mm gold connector into one of the power leads, with the female half glued into, and poking through, the fuselage side, and the wire with the male part on poking through the side too. To energise, I just plug the male into the socket.
On all my other models my battery connectors (Deans Ultra) are my arming switch.
abenn is offline Find More Posts by abenn
Old Jul 21, 2007, 04:09 PM
makarov380 is offline
Find More Posts by makarov380
makarov380's Avatar
Grapevine,Texas
Joined Mar 2005
I like this method. The mounting bracket is from Maxx Products- #6970-1
http://www.rcgroups.com/forums/showp...&postcount=114
makarov380 is offline Find More Posts by makarov380
Old Jul 21, 2007, 05:01 PM
jrb1 is offline
Find More Posts by jrb1
up north, mn, usa
Joined Oct 1999
search mode
jrb1 is offline Find More Posts by jrb1
Old Jul 21, 2007, 05:15 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Here's what I like to do; only fly electric:
jrb is offline Find More Posts by jrb
Old Jul 21, 2007, 05:30 PM
bama_bruce is offline
Find More Posts by bama_bruce
Joined Jul 2007
Re: Arming switch
If anyone can post a picture or 2 of the MPI Arming switch part # 6970 showing how you have it hooked up I sure would appreciate it. I'm new to EPower and thought the MPI would be a simple install I have been looking for pictures showing how it is hooked up I assume one set of the switch goes to the power leads and the other to the ESC wires?
Thanks Bruce
bama_bruce is offline Find More Posts by bama_bruce
Old Jul 21, 2007, 05:53 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Pat,
Try not to post the same subject in two forum, hard to keep track what is going on.....
see http://www.rcgroups.com/forums/showthread.php?t=716437
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Jul 21, 2007, 06:53 PM
USA, KS, Wichita
Joined Sep 2002
Brian,
Sorry, I was not sure which forum would be the best one to post in. Thanks to all you guys for all your help.
See Ya,
Pat
Old Jul 21, 2007, 07:02 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
jrb,
What is the wire loop with the spade connectors for?
Does it replace the fuse for measuring current with a clamp on type of meter?
What about the thing inset on the top right of both pictures?
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Jul 21, 2007, 08:16 PM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
Jrb
That charging connector can handle the high current of charging? 3-4 amp?
Problem may be over charging the battery, voltage drop cross the connector may fool the charger to sensor a lower voltage than the pack is actually at, thus over charged the pack. Specailly bad for lipo. Not so for nicad and Nimh, they only sense the voltage peak regardless of the voltage.
Pat MacKenzie, The wire loop replaces the fuse in the system to check the current draw with a clamp meter.
Brian, an EAJ
Old Jul 22, 2007, 07:08 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Iíve used 35amps fuse to 30 & 40 to 35; for nearer 40 I made the shorting plug Ė only use it now.
The loop of 14ga wire is a shunt; lets me measure installed current w/o breaking into the wiring via multimetter -- precise .01ohm resistor, each .01 volt = 1amp.
With voltmeter plugged into the charging jack you can also get loaded volts; so then watts too!
Iíve had no problems pumping 6amps through the jack.
Question Arming Switch Question pmccleave High Performance 50 Jul 29, 2007 08:57 PM
JR 8103 flap/throttle mixing with gear switch question bfraser Electric Sailplanes 0 Aug 30, 2002 06:50 PM
Can an arming switch on esc be bypassed? omega blood Power Systems 4 Feb 22, 2002 02:03 PM
Arming switch - charge jack KatManDEW Power Systems 4 Dec 03, 2001 06:09 PM
Can I put an arming switch in a signal wire? Capt. Dave Power Systems 3 Jul 03, 2001 04:15 PM
