Old Jul 08, 2005, 04:26 PM
Starguard is offline
Find More Posts by Starguard
Going Home
Starguard's Avatar
Mighty Midwest
Joined Apr 2004
Have question:Need Advice
What would be the best receiver battery for this setup using Futaba Flight Pack with an R127DF Receiver and 4 S3004 Servos?
Starguard is offline Find More Posts by Starguard
Old Jul 08, 2005, 04:58 PM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
The stated Futaba Flight pack includes a 4.8 v x 600 ma battery pack.
Viper Pilot is offline Find More Posts by Viper Pilot
Old Jul 08, 2005, 05:05 PM
Going Home
Starguard's Avatar
Mighty Midwest
Joined Apr 2004
Old Jul 08, 2005, 05:13 PM
God is good
Banjul
Joined Jan 2001
You COULD use a 6.0 v x 600 ma also. Adds a little weight, but speeds up the servos considerably.
VP
Old Jul 08, 2005, 05:54 PM
Mendnwngs is offline
Find More Posts by Mendnwngs
Firebreather
Mendnwngs's Avatar
Napa, California, United States
Joined Jul 2004
..if you were paraniod, you could do like I have and use a 6V (5 cell) 1800mAh pack..
Servos will draw about 20-30% more power from a 6V pack than a 4.8V pack, so in order to get the same flight time from a 6V pack, youll need to get a higer capacity than the 4.8V pack.
The 4.8V 600mAh pack is the standard, and with 4 s3004 servos, you should get better than 50 minutes flight time before the batteries get questionable. But as is good practice, check your bats before each flight, and if in doubt at all.. charge 'em.
A charge is a cheap insurance against losing your plane due to dead batteries.
-Jason
Mendnwngs is offline Find More Posts by Mendnwngs
Old Jul 10, 2005, 08:12 AM
cornbinder is offline
Find More Posts by cornbinder
Yerington,nevada
Joined Jun 2003
i second what jason says and a plus is that if a cell goes bad you still have
the original 4.8v that the system needs.mike
cornbinder is offline Find More Posts by cornbinder
Discussion Tekoa Core Cutting Question--need advice theclaw Sailplane Talk 3 Mar 30, 2007 12:07 AM
Question Have a Ditto Tape drive motor and need advice ProudTexan Electric Motor Design and Construction 20 Oct 19, 2006 12:37 PM
Question Aveox question (need advice) kyredden Power Systems 1 Dec 09, 2005 11:27 PM
Need advice so I only have to do it once. stickflyer Aerial Photography 14 Jun 11, 2005 09:46 AM
Formosa Brushless Power question-need advice! mrebman Parkflyers 24 Apr 22, 2004 10:37 PM
