Old Dec 22, 2004, 02:04 AM
orion1210 is offline
Find More Posts by orion1210
orion1210's Avatar
Leeds, UK
Joined Aug 2004
Banana Electric Configurations
Hi guys,
Just wondering what battery/servo/Rx configurations your all ended up using in the Baudis E-banana?
I've read that the GP's were the way to go a while back, but there still not available in the UK to my knowledge.
I'm using a mega 20/22/3 direct drive with 7 CP1300. But need more oomph!!!
orion1210 is offline Find More Posts by orion1210
Old Dec 22, 2004, 06:35 AM
luvbus is offline
Find More Posts by luvbus
United Kingdom, England, Ingleby Greenhow
Joined Aug 2004
Me,
I'm using a typhoon 10/13 with a 11x8" prop, kokam 3s 2100mah pack. The Banana goes vertical (the speed does bleed off after a couple of hundred feet!) so I am going to try a 12x6 1/2". I have got HS5125's in the wing (there was an availability issue with standard HS125's in the UK when I put mine together!) and 2xHS55's in the fuz for the v-tail.
Hope this helps,
Rich
luvbus is offline Find More Posts by luvbus
Old Dec 22, 2004, 06:54 AM
orion1210's Avatar
Leeds, UK
Joined Aug 2004
Do you have any idea how much current your pulling on that set up?
Where have you situated your Rx?
Cheers
Old Dec 23, 2004, 09:27 AM
luvbus is offline
Joined Aug 2004
Pulling about 30amps, at the top end of the motors range but you only need a very short motor run (10sec ish) to have the banana up as far as you can see it and still fly. Much less for stooging around.
The receiver is sited aft of the rudder servos (which you have to remove to get at it) and is a long narrow type, can't remember the manufacture off the top of my head.
Hope this helps,
Rich
Banana Electric..... help me... akita Electric Sailplanes 1 Nov 25, 2004 02:54 AM
