Old Sep 14, 2004, 04:36 PM
bobbart is offline
Find More Posts by bobbart
Joined Nov 2003
***counter rotating propellers on a C-130?
Does the below Article refer to this C-130 which I building, please go to link below to see the plane.
http://eapg.org/Reference/C-130/Instructions.htm
Article:
On a two motor airplane that one motor turns the propeller clockwise and the other motor turns the propeller counter clockwise. Because the motors run in different directions (and the propellers turn one clockwise and the other counterclockwise) you eliminate the need for right thrust.
-on a four motor airplane you will have one wing with two motors turning clockwise and one wing with two motors turning counterclockwise.
If the design of the plane is not originally for counterrotating motors (and propellers) you will have to eliminate the rightthrust that is normally build in the way the motors are mounted.
Bob
bobbart is offline Find More Posts by bobbart
Old Sep 14, 2004, 06:51 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
This is a cure to a non-existent problem.
All motors on 4-motor planes turn in the same direction.
Singles and twins have "p-factor" problems which don't occur with the 4-motors.
Sparky Paul is offline Find More Posts by Sparky Paul
Discussion counter rotating propellers ashvani VTOLs 1 May 25, 2007 01:08 PM
Counter rotating propellers? blimpyway Coaxial Helicopters 4 May 21, 2005 10:57 PM
Electric Counter Rotating Propellers CaptKirk Scale Kit/Scratch Built 12 May 19, 2005 10:24 PM
*****Help on an C-130 Propeller***** bobbart Electric Plane Talk 2 Sep 09, 2004 05:20 AM
Question ***Help on an Electric C-130 ***** bobbart Electric Plane Talk 7 Sep 04, 2004 05:26 AM
