Old Apr 19, 2015, 02:07 PM
CRASHLEY77 is offline
Find More Posts by CRASHLEY77
CRASHLEY77's Avatar
Joined Mar 2015
Mini-HowTo
Xtreme Spin 4400 Motor (GREAT 450 Motor!!)
I installed a Spin 4400 kv motor on my 450 SE. Here is my setup:
- Spin 4400 kv Motor
-YEP 60 amp ESC (I switched to the YEP after this video)
-3S battery setup
-11 tooth pinion
-150 tooth main
This is an un-boxing and install video. May help someone! I have about 100 flights on this motor and it is amazing. May have more power than my Scorpion!
Xtreme Productions Spin 4000 kv Motor (24 min 52 sec)
CRASHLEY77 is offline Find More Posts by CRASHLEY77
Old Apr 19, 2015, 05:05 PM
Flying Pitcher is offline
Find More Posts by Flying Pitcher
I'm breaking-in helis.
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
2s setup on 450? hmm, that must be like 600 on 6s i guess. if it works...
(i didn't watch the vid)
Flying Pitcher is offline Find More Posts by Flying Pitcher
Old Apr 19, 2015, 05:41 PM
CRASHLEY77's Avatar
Joined Mar 2015
Typo, 3S.
Old Apr 19, 2015, 06:53 PM
Joined Apr 2013
o. umm, 4400kv ?? i have 3600kv and with 13t pinion, it RUNS!!
Old Apr 20, 2015, 12:44 AM
CRASHLEY77's Avatar
Joined Mar 2015
The 4400 kv Spin is unbelievable. I was running a 3600 prior to this. My ESC went bad and took my motor with it, or motor went bad and took my ESC with it. It was hard to tell because the were both melted.
I ran across this Spin 4400 and picked it up for $20.00. I did not trust it so I did not install it at the time. When I ordered it I also ordered a Scorpion 2221-6, which was also a 4400kv motor. Well the Spin came in first and i was down a motor so I installed it. I was shocked at the power!
My head sped is around 3100, which is where I like it. But the torque I am getting because of the motor RPM is ridiculous. I wanted to beat the motor up a little so I decided to run a 60 amp ESC. Well it has handled all I can dish at it. Motor comes down warm but not hot. I wanted to fly it a bit before I recommended it to anyone. I can tell you this, my Scorpion 2121-6 is still in the box, and will be until this one gives up. It shows no sign of giving up yet.
I don't run the most expensive packs (2200 mah Turnighy, 30C). Actually I run a very cheap pack! I set my timer for seven minutes and I have no trouble. When I get home from Kuwait I am going to order some good packs (oh did I mention I was flying in 110 degree weather ).
Just thought I could recommend a motor that has been good to me.
For Sale Xtreme Production Spin 8200Kv Brushless Motor for mCP X BL or 2s Power mCP X BladeScraper Aircraft - Electric - Helis (FS/W) 0 Nov 12, 2013 10:57 AM
For Sale NIB Xtreme Production Spin MCPX motor 16000kv Elec 1800 Aircraft - Electric - Helis (FS/W) 0 May 08, 2013 08:53 AM
For Sale NIB Xtreme Production Spin MCPX motor Elec 1800 Aircraft - Electric - Helis (FS/W) 0 Nov 18, 2012 08:45 PM
Sold Xtreme mcpx spin brushless motor ER8SR Aircraft - Electric - Helis (FS/W) 3 Apr 18, 2012 02:17 PM
Sold Align Trex 450 PRO - RX ready with Scorpion 6 Next D 4400 KV motor dnorm Aircraft - Electric - Helis (FS/W) 1 Jul 14, 2009 03:23 AM
