Old Jul 05, 2014, 06:30 AM
jpgilbert is offline
Find More Posts by jpgilbert
MaineFlyer
jpgilbert's Avatar
Augusta, Me
Joined Feb 2005
Help!
Multiplex Pilatus PC6 - ESC Issue
Just assembled my new PC6 and find the ESC will not run the motor. Just a constant series of beeps. All servos function fine.
I am using a Spektrum AR610 receiver and added a new configuration on my DX9 transmitter.
I replaced the ESC with a CC Thunderbird 55 and all works OK. Motor start as it should.
One more question. Does this ESC use a switch mode BEC or linear? I ask because I wonder if the CC TB 55 can support the six servos.
What next? Should I call Tower where I bought it or call Hitec?
Thanks for your help.
Joe
jpgilbert is offline Find More Posts by jpgilbert
Old Jul 05, 2014, 08:04 AM
Bajora is offline
Find More Posts by Bajora
KK6MQJ
Bajora's Avatar
Joined Sep 2004
Joe,
Did you try running your throttle trim all the way down? Sometimes an ESC will not recognize the normal throttle off position; try to drop it further using trim or sub trim?
Bajora is offline Find More Posts by Bajora
Old Jul 05, 2014, 08:32 AM
MaineFlyer
jpgilbert's Avatar
Augusta, Me
Joined Feb 2005
THANKS!!!
That did it. I used the trim and went all the way down with it and it worked. First time I ever had to do that but I mostly use CC ESCs but I don't argue with success!
Thank you very much for the quick response! Now I just have to wait til hurricane Arthur gets out of here so I can fly it!!
Appreciate it!
Joe
Old Jul 05, 2014, 09:33 AM
Bajora is offline
KK6MQJ
Bajora's Avatar
Joined Sep 2004
Multiplex contracts with Castle Creations on at least some if their ESCs? If you look closely at them, you can often see their name printed on the wires.
Glad that got you going!!
Discussion Pilatus PC6 Porter Jab69 Foamies (Scratchbuilt) 2 Jun 24, 2014 07:11 PM
Contest Scale Build-Off 3 "Pilatus Porter PC6 (1/8.5 scale)" czirh Scale Kit/Scratch Built 15 May 31, 2014 01:48 AM
Discussion Pilatus Porter PC6 czirh Scale Fuel Planes 4 Jan 26, 2014 09:44 PM
Need Pilatus PC6 3 view DBlum Scale Kit/Scratch Built 11 Sep 20, 2004 06:34 PM
Sold FS: Pilatus PC6 Porter Plan Rudderman98 Aircraft - Electric - Airplanes (FS/W) 2 Nov 12, 2003 10:47 AM
