Old Jun 27, 2013, 01:35 AM
SeismicCWave is offline
Find More Posts by SeismicCWave
Hawaii
Joined Feb 2003
HoverFly Pro green board question.
Is there a data log in the HoverFly Pro green board. I had my old quad with the HoverFly Pro tumbled out of the sky at about 100 feet high. I found the quad and everything seems to be working just fine on the bench. I will pull the hardware and out them on a test frame to make sure all is working ok before putting a gimbal and camera on it again.
In the meantime I just want to know why it fell. The right front arm dipped. I am suspecting a corroded motor to ESC connector right now. Other than that I have no clue because everything works.
So I am curious if the HoverFly Pro has a log to tell me if it tried to increase power to one motor to compensate for something during the flight.
Thanks in advance.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Jun 28, 2013, 09:14 AM
mspencer is offline
Find More Posts by mspencer
Flight Instructor
Chico, CA
Joined Jun 2008
It sounds motor or esc related. I was having an intermittent issue on a large octo. The rear arm would occasionally drop out. Since it was an octo it continued to fly but it was scary. I thought it was firmware related but it wasn't. I replaced the esc but no change. The day I decided to replace the motor it finally began to smoke and cooked while in the air. The ship kept flying and the motor was fully dead. Check your motor, esc, connections, everything. You name the problem and I've had it happen.
mspencer is offline Find More Posts by mspencer
For Sale Hoverfly Pro board and Hoverfly Sport board for sale MellumMan Aircraft - Electric - Multirotor (FS/W) 6 Jan 13, 2013 03:17 PM
Discussion hoverfly pro green board for sell 280$ windfou Hoverfly Technologies 2 Aug 14, 2012 09:33 PM
For Sale Hoverfly Pro Green Board Protective Case Greasetattoo Aircraft - Electric - Multirotor (FS/W) 5 Apr 17, 2012 10:21 AM
Discussion Hoverfly Pro Green Board Protective Case Greasetattoo Hoverfly Technologies 6 Apr 05, 2012 05:43 PM
Discussion HoverFly Pro Green Board for sale cdi3d Hoverfly Technologies 2 Oct 23, 2011 08:14 AM
