Old Nov 11, 2014, 03:38 PM
Iscold is offline
Find More Posts by Iscold
ISCOLD
Joined Mar 2014
Blutoh
"Did you do the calibration sequence, as in Dutchraptor's video and instructions? If you are getting sound from the speaker when you first boor up the raspi, then I think that may be the problem."
Yes, I do.
Dutchraptor
When you hook up the arduino to a normal pc with the gui: do you see any commands in the serial monitor? Did you install the serial library on the raspberry (or is that not needed anymore Blutoh?)
No commands. When I hook up the arduino to pc with the gui, I get a blank window, without commands, only baude rate 9600 and COM10 . On RASP in serSoundfx.py I have the following line: Serial Communications
ARDUINO = (config Section Map ("Serial") ['port'])
Now I try only one connection between RC receiver and Arduino, as you can on attached photo.
But, until now, no sound. Sorry.
Iscold
Iscold is offline Find More Posts by Iscold
Old Nov 11, 2014, 03:40 PM
Iscold is offline
ISCOLD
Joined Mar 2014
Attached photo
Old Nov 11, 2014, 05:21 PM
Dutchraptor is online now
Find More Posts by Dutchraptor
Dutchraptor's Avatar
The Netherlands, ZH, Hoogvliet
Joined Jul 2008
Iscold,
Do you have a GND wire connected between the receiver and Arduino? I can't see it in the picture. You need this because the system doesn't know what the puls is. I needs the common GND.
To test a single channel, you can try this little program I wrote. You can hook up the desired receiver channel. You can power the receiver with the arduino or use a seperate power supply for the receiver. When you use a seperate power unit, you also need a common GND (only gnd NOT 5volt +).
good luck,
keep us posted.
Danny
Code:
int PPMin = A0;  // connect the desired channel (PPM signal) from your RCreceiver to analog pin 0
int RCval;  // store RC signal pulse length
int adj_val;  // map that value to be between 0-255
int minvalraw = 969; // adjust accordingly what you read from the receiver
int maxvalraw = 1965; // adjust accordingly what you read from the receiver
int minval = 0; // adjust accordingly what your minimum output value should be
int maxval = 255; // adjust accordingly what your minimum output value should be
void setup()
  Serial.begin(9600); //serial library start
  pinMode(PPMin, INPUT); //Pin 14 as input
void loop()
  //-----------------------  Receiver readout ---------------------------//
  RCval = pulseIn(PPMin, HIGH, 20000);
  adj_val = map(RCval, minvalraw, maxvalraw, minval, maxval);
  //------------------------  Send to Serial ----------------------------//
  Serial.print ("rawvalue: ");
  Serial.print (RCval);
  Serial.print (" / ");
  Serial.print ("adjusted:  ");
  Serial.println (adj_val);
Dutchraptor is online now Find More Posts by Dutchraptor
Old Nov 12, 2014, 04:58 PM
Iscold is offline
ISCOLD
Joined Mar 2014
Dutchraptor:
Yes, all the time I have both GND connected.
With your above Arduino code the results are:
Transmiter: on
Receiver: pulse on channel 3 = Throttle
Arduino: pulse entrance A0
When Throttle on maximum, serial window appear:
rawvalue 1694 until 1704/adjusted 185 until 188
When Throttle on minimum, serial window appear:
rawvalue 1283 until 1289/adjusted 80 or 81
This means the Arduino Serial is OK.
I tested all other three receiver channels and they are also OK.
I tested all other Arduino analog in (A1;A2;A3;A4;A5) and they are also OK.
Then, the next step will be the serial on RASP. For this I need help again.
Thanks a lot
Iscold
Old Nov 13, 2014, 02:42 AM
Joined Jul 2008
I think the best option should be to connect everything to tre Arduino the way it should and test it connected to the pc and see what commands you get in the serial monitor. Remove de slashes in front of DEBUG and place 2 slashes in front of RASPBERRY and the upload it. You should see stuff like switchstate, eeprom values and commands given to what will be the raspberry.
Goodluck,
Danny
Old Nov 17, 2014, 06:52 PM
Iscold is offline
ISCOLD
Joined Mar 2014
Dutchraptor,
I make the test on Arduino. I get the following results on serial COM10.
When throttle is up position:
Reading high end of A0: 1658 Reading high end of A0: 0
Switch: 0 / 0 / motorstate1: 0 / motorstate2: 0
Reading high end of A0: 1660 Reading high end of A0: 0
Reading high end of A0: 1666 Reading high end of A0: 0
When throttle is down position:
eading high end of A0: 1254 Reading high end of A0: 0
Reading high end of A0: 1254 Reading high end of A0: 0
Reading high end of A0: 1233 Reading high end of A0: 0
When I use Channel 4 I get two values:
22504
22002
When I use Channel 2 I get two values:
21508
Switch: 0 / 1 / motorstate1: 0 / motorstate2: 0
21004
Iscold
Old Nov 18, 2014, 01:43 AM
Joined Jul 2008
Reading part is only when you're in calibration mode. So I guess the Pin2 (cal.pin) is connected to gnd.
Switch: 0/0 means that the switches for ambient and crew sound (pin 5+6) are not active (connected to gnd)
motorstate1: 0 / motorstate2: 0 means that both the switches for the engine sounds are not active (not connected to gnd)
The other 2 channels seem to work fine accept that you get commands that don't make sense. Do you use a 2 way switch or sticks? But it can be fixed (easy). I can see you're using a 9x, needs some settings to assign channels to sticks (you can use 2 switches on 1 channel). Does it have the normal firmware? The middlevalue is read at startup, from that point on it calculated the commands for the rc switched functions/sounds.
Danny
PS: the second A0 supposed to be a A1 (copy/paste error in the program) for reading the second motor input. It's reading nothing (I guess it's not connected or commented out)
Old Nov 18, 2014, 06:31 PM
Iscold is offline
ISCOLD
Joined Mar 2014
Dutchraptor,
I will use switch for:
Start motor number one (digital pin 3 and GND)
Start ambient and crew sound (digital pins 5,6 and GND)
I will use push button for:
Motor calibration (digital pin 2 and GND)
Throttle command receiver channel 3 to Arduino A0 and GND
Siren command receiver channel 2 to Arduino A2
Horn/Foghorn command receiver channel 3 to Arduino A3
My radio system have the ER9X firmware
I can not understand this statement.
In which line of program I must change A0 to A1? I am not using the motor number 2.
Iscold
Old Nov 26, 2014, 04:02 AM
Iscold is offline
ISCOLD
Joined Mar 2014
Dutchraptor, Blutoh:
Many tanks for your help me in order to make operational my Soundfx. Now my boats will make sounds.
My main problem, I think, was the communication address between Arduino UNO and RASP.
Iscold
Old Nov 26, 2014, 05:29 AM
Joined Jul 2008
congratulations, now have some. You earned it.
Danny
Old May 03, 2015, 07:17 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Interpreter for Arduino Mega
Guys,
I am helping a friend set up the sound system, using a remote switch similar this one to activate the sounds (see pix below). If you use an Arduino Mega as the interpreter, you can set it up to perform 15 sounds with this type of switch, as well as perform the interpreter function for the varying throttle sound effects. This is because the Mega has more I/O pins than the Uno. I took Dutchraptor's LITE interpreter posted here and made a few tweaks for the mega. To use it just unzip it into your sketchbook directory, compile it in the Adruino (don't forget to set the board to Mega) and then download it to the mega board.
Have fun!
Blutoh
blutoh is offline Find More Posts by blutoh
