Old Dec 18, 2012, 12:00 PM
kitman09 is offline
Find More Posts by kitman09
United States, TN, Greenbrier
Joined Aug 2009
hair spray for sanding sealer
hi, can auqunet hairspray be used as a sanding sealer. i am getting ready to cover a pt-19 with 100% polyester dress lining and polycrylic. thanks.
kitman09 is offline Find More Posts by kitman09
Old Dec 18, 2012, 04:18 PM
carrier flyer is offline
Find More Posts by carrier flyer
United States, OH, Ashtabula
Joined Jan 2009
sealer
Hello,
I've used it several times with no problem under poly. Make sure you put on several coats lightly sanding between coats. Buy the least expensive can you can find. I think I paid $2.00 for a large can at Walmart. You can also use Minwax sanding sealer of their spray lacquer. This stuff stinks like a good lacquer should.
I've seen several post that they do not ues a sealer, but I've have numerious problems not using it.
Rick
carrier flyer is offline Find More Posts by carrier flyer
Old Jan 02, 2013, 11:06 PM
Leroy G is offline
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
The problem with hair spray is it's mostly water and will raise the grain with every coat weather you sand it or not because it's water soluble. Deft sanding sealer works great, it's laquer so dries fast and sands easily with 400 grit. If I'm covering it's gonna get the laquer treatment and the covering sticks better. Don't take my word on it do your own test with some scraps and you will find the covering on un treated balsa will pull right off. Leroy
Leroy G is offline Find More Posts by Leroy G
Question Talcum Powder and nitrate dope for wood sanding sealer RiceLover36 Free Flight 6 Dec 29, 2010 03:53 PM
JK Perkins Sanding Sealer thething84 Scale Boats 10 Apr 11, 2005 04:00 PM
Foam Sanding Sealer / Filler : Tip BlueFielder The Builders Workshop 3 Jun 28, 2003 04:44 PM
Compatible sanding sealer? Doc Data The Builders Workshop 0 Sep 14, 2002 10:13 AM
Sanding Sealer & 'cote? tiggs Electric Plane Talk 4 Jun 18, 2001 11:39 AM
