Old Nov 13, 2012, 01:40 PM
rcflyinff is offline
Find More Posts by rcflyinff
rcflyinff's Avatar
United States, FL
Joined Mar 2012
Question
Wing Powerplant?
I'm not sure if I should be posting here or the scratchbuilt forum, but here it goes. I had a very nice gentleman give me a blue foam wing minus the electronics of course. It is a 31" wing. What motor would you recommend me using on this. Also prop size and battery wouldn't hurt either Thank you for your help.
rcflyinff is offline Find More Posts by rcflyinff
Old Nov 13, 2012, 01:48 PM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Sounds like you need something thats similar to a Swift 2 then going by that size. :
Parameters:Motor TW-20-26MMeasure: 23x 28mm dia.Weight: 49g:Voltage: 7,2 – 11,1V (2S-3S LiPol/LiIon)KV:1150 RPM/VoltESC TW-15AMeasure: 50x23,5x8mmWeight: 15gVoltage range: 7,2 – 11,1V (2S -3S LiPol/LiIon)Current: 15AMax. Current: 16A / 10sBEC: 1A, 5,5VServos TW-TG9EMeasure: 12x22,5x23mmWeight: 9gTorque: 1,5kg/cmSpeed: 0,10s/45°Voltage range: 4,8 – 6VProp: 8x6“Recommended acessories:Power accu LiPol 3s (11,1v) 1200 – 1500mAh min. 20C discharge current.RC set with minimum 3 channels with ELEVON mix ( V mix) External V mix MS... (if transmitter is not equipped)Connectors for power accu connection ( depends on accu)Close window
PHMX is offline Find More Posts by PHMX
Old Nov 20, 2012, 12:47 AM
conbones is offline
Find More Posts by conbones
AMA# 1004189
conbones's Avatar
United States, FL, Panama City
Joined Jun 2012
its 100W per pound generally. 370 to 400 size BL motors with 3s or 4s 1000-1500 mah bats with 18-30amp esc somewhere in that range for good all around flying.
conbones is offline Find More Posts by conbones
Help! Powerplant requirements for Quadrotor Vishnuasalways Power Systems 11 Mar 14, 2012 01:41 PM
Sold HImax inrunner motor and 70mm edf unit (stock Twister powerplant) $25 shipped sherlockshah Aircraft - Electric - Power Systems (FS/W) 0 Mar 06, 2012 08:33 AM
How fast is your wing powerplant?? c/f Flying Wings 3 Nov 01, 2005 01:23 PM
Powerplant for 18" wing... Suggestions? ndflicks Scratchbuilt Indoor and Micro Models 24 Oct 30, 2003 10:25 PM
Powerplant on flying wing? NightSwan Parkflyers 1 Jun 24, 2002 01:29 PM
