Old Nov 05, 2012, 03:50 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Idea
FY-21AP/FY-31AP and OSD FY Extender
Hey guys,
one of the key features that this combo (autopilot and osd) is missing is RSSI monitor and there is no easy way to solve it. One of the options is to overlay info from another OSD such as Super Simple Mini OSD but you can't turn that overlay on/off and OSD's are overlaying each other.
So, to solve this I'm planning to create more elegant solution for this which could also be used to attach additional sensors such as pitot tube and use existing OSD to display the info on screen (instead of some other unused info) and the same board is going to be used for telemetry purposes and antenna tracking.
Idea is to use Arduino Mega 2560 (or similar board with multiple UARTs) which will be placed between FY-21AP/FY-31AP, OSD and the rest of the equipment.
The same board is going to be used as audio modem to relay telemetry data to ground.
Comments and suggestions are welcome.
UPDATE1: Successfully decoding information sent from FY-21AP II and feeding AP117.
hefest is offline Find More Posts by hefest
Old Nov 05, 2012, 04:10 AM
julie32 is offline
Find More Posts by julie32
United States, GA, Atlanta
Joined Oct 2009
Having true airspeed would be cool.
julie32 is offline Find More Posts by julie32
Old Nov 05, 2012, 05:31 AM
TimeTrave1er is offline
Find More Posts by TimeTrave1er
United States, CT
Joined Oct 2012
Very cool idea. Do it!
TimeTrave1er is offline Find More Posts by TimeTrave1er
Old Nov 05, 2012, 01:51 PM
Opt is offline
Opt
Find More Posts by Opt
Opt
New Zealand, Auckland
Joined Oct 2010
You can get an RSSI input into the hornet by replacing the voltage sense wire from the current sensor (red) with the RSSI input voltage. Then Veng will be RSSI and Vav will tell you your flight pack voltage.
also the hornet uses an ARM processor, maybe you could reprogram that?
Opt is offline Find More Posts by Opt
Old Nov 05, 2012, 02:51 PM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Good idea, if you use one 3S unregulater pack to power it all.
In my case I'm powering motor with 4S and onboard electronics with regulated 12V.
Switching to Remzibi OSD could solve the RSSI issue but my intention is to use the same circuitry to extract telemetry data from FY-21AP and send it via audio to the ground. One more possible option is to use this board as PPM sum "gateway" to simplify wiring to the RC RX.
So far I've successfully decoded data coming from FY-21AP.
Old Nov 05, 2012, 04:18 PM
Opt is offline
Opt
Opt
Joined Oct 2010
I use 4S too, but power the hornet from the 3S balance tap to get an idea of my pack voltage. You can power the Hornet with 4S, but there is an internal 6V linear regulator that gets very hot so needs lots of airflow. I have been thinking about moving the 6V regulator outside the case and heatsinking it so powering the hornet from 4S is safely achieveable.
What information is contained in the fy31 - hornet serial feed?
Good work though, I like your idea. Will be interesting to see what you can do with the data.
Old Nov 05, 2012, 04:45 PM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
I'm testing this with FY-21AP II and AP117 OSD but I think that information passed trough did not change with FY-31 and Hornet.
Voltages and current information (both) are not passed via serial because those are connected directly to AP117.
Useful is GPS data which could be used for telemetry and I'm planning to periodically substitute temperature and/or satellite information with RSSI and/or airspeed.
New Product FY 21AP Stabilizer with OSD Hooks FPV Equipment 2453 Jan 04, 2015 01:59 PM
Wanted FY 31AP + Hornet OSD swartzracing FPV Equipment (FS/W) 6 Nov 17, 2012 09:51 AM
Sold FY - 31AP Autopilot Path Navigation & Hornet OSD Combo GPS For RC Airplane mamut FPV Equipment (FS/W) 1 Sep 08, 2012 05:34 AM
Question FY-31AP/Hornet - No Voltage on OSD? Wayno Complaino FPV Talk 7 Mar 30, 2012 04:26 AM
New Product FY 21AP Stabilizer with OSD Hooks FPV Talk 0 May 03, 2010 03:07 AM
