Old Jul 17, 2012, 04:06 AM
kgordeev is offline
Find More Posts by kgordeev
Joined Mar 2012
Help!
No reaction with Throttle it's always 0.
Hi guys
I have the strange problem.
OSD doesn't see Throttle. In servo wizard the Throttle in the all screen's have value -100%. I put in the screen Th E R but Th it's always 0.
In pin throttle out I connected the servo and it move with throttle stick!
I have no logger connected with Y, I try to change the RX channel and the same problem.
My OSD have next firmware:
Expander 2.66
Logger 1.21
maybe someone had a similar problem?
Many thanks
Best regards,
kgordeev is offline Find More Posts by kgordeev
Old Jul 17, 2012, 10:57 AM
EugeneFlorida is offline
Find More Posts by EugeneFlorida
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
Originally Posted by kgordeev View Post
Hi guys
Expander 2.66
Logger 1.21
Many thanks
Best regards,
try rerunning the Servo Analysis Wizard
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Jul 19, 2012, 04:25 AM
kgordeev is offline
Joined Mar 2012
Hi EugeneFlorida,
I did the Wizard 100 times and nothing happens
Finally I decide to change my RX to SUM PPM mode and now it's work with SUM.
I think something wrong with Thrrotle In channel in my OSD. it's strange because I bought it only 3 days ago.
Old Jul 19, 2012, 09:43 AM
KJ4YYJ
Saint Petersburg FL
Joined Jun 2009
Hi EugeneFlorida,
strange Yes... I would think the wires going out to the receiver is bad or on up side down. because you remove that wire to use SPPM.
If this was mine I would want to get it working or send it back and get one that works right.
My best guess is the OSD is OK.
Old Jul 23, 2012, 02:04 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi kgordeev, to make sure I understand, when you connect the Rx's throttle output to the OSD's throttle input, and then connect a servo to the OSD's throttle output, the servo moves correctly?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Aug 05, 2012, 03:43 AM
elky82 is offline
Find More Posts by elky82
Joined Dec 2009
I am having this identical problem. My speed controller will not arm, I have the system powered by a 5 amp BEC and the positive wire from the speed controller is disconnected. I am running a dragon link reciever running in PPM mode with 1 wire connecting to the aileron channel. In the PPM setup screen I can see the throttle channel moving correctly but cant get the speed controller to arm at all, no matter if I reverse the throttle channel or not. Tried a servo on the throttle out of the OSD and it works fine when I move the throttle stick. Hooked up a different reciever to the speed controller directly and with a 4.8 volt pack reciever pack it works fine so nothin is wrong with the speed controller or motor. What gives??
elky82 is offline Find More Posts by elky82
Old Aug 08, 2012, 01:38 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi elky, sorry to hear about your issue.
We made a change involving SPPM, linked to here, which might address your issue. If you could give that a try, that would be great. Note that this is "alpha" level software with limited testing, so pls do throrough bench testing, etc.
Site Sponsor
Help! HELP with Micro Servos, DX7, and AR6100. Servos no reaction??? Littlesopwith Electric Plane Talk 3 Jun 06, 2009 11:14 AM
Help! HELP with Micro Servos, DX7, and AR6100. Servos no reaction??? Littlesopwith Electric Motor Design and Construction 2 Jun 06, 2009 07:51 AM
Help! HELP with Micro Servos, DX7, and AR6100. Servos no reaction??? Littlesopwith Power Systems 2 Jun 06, 2009 05:11 AM
Question Old OS 20 no throttle control (quiet always at max. speed) elgatosuizo Engines 3 Jun 24, 2008 04:49 AM
Question No throttle and no braking with Phoenix with brake enabled. Possible? Jan_B Castle Creations 3 May 14, 2007 11:04 AM
