Old Apr 28, 2013, 04:52 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
I got my MCFC back in the air and everything is working good now. I loaded the latest firmware and poof worked. no issues . Minsoo came thru with some new arms for the frame.
tc3wins is offline Find More Posts by tc3wins
Old Apr 29, 2013, 10:06 AM
Ophtalmicus is offline
Find More Posts by Ophtalmicus
Joined May 2012
"Channel 5" and Auto take off and Landing
Hi all,
There has been discussion on three position switch concerning "Channel 5" to operate auto takeoff, altitude hold and auto landing. Functionality is described by Minsoo and others. If you do not have three position switch available you might be able to obtain same functionality by mixing two switches with two positions each. We set up one two position switch to change signal from "off" (1088) to "auto take off" (1500) and another two position switch mixed to same output from TX to raise signal to "auto landing" (1800 or higher). This way one can establish both functions without having a three position switch available. Disadvantage is that one could accidentally initiate auto landing if the switch is flipped due to mistake.... Anyway, this is something to think about. It works fine with us. Good luck. Regards Ophtalmicus
Ophtalmicus is offline Find More Posts by Ophtalmicus
Old May 12, 2013, 05:56 AM
ikotikot is offline
Find More Posts by ikotikot
Joined May 2008
i was trying to resurrect my quad bb+navi2 and i managed to get it in the air again.
autolevel is working but the altitude is so bad, the quad needs continuous throttle input to maintain altitude. i don't have the sonar module.
my question, is it possible to maintain altitude (i mean maintain the quad in steady altitude) without the sonar?
thanks.
ikotikot is offline Find More Posts by ikotikot
Old May 31, 2013, 04:30 PM
drew112 is offline
Find More Posts by drew112
Joined May 2013
Dear Mr. Minsoo
I am beginner making Xcopter usiing kkmultiboard,
i have calibrated esc, and able to arm the flightboard.
but when i am moving throttle stick one of the motor is not working i have installed Xcopter v2.5 by Minsoo Kim.
also i am using simple FS-C6B transmitter and don't know the calibration steps what value to set
please help me .
please.
drew112 is offline Find More Posts by drew112
Old Jun 02, 2013, 11:49 AM
GeO82 is offline
Find More Posts by GeO82
Belgium, Vlaams Gewest, Sint-Truiden
Joined Jul 2012
Autoland problem
There have been some successful auto landings but sometimes wen i
engage autoland the motors stall in mid air?anybody had this problem??
GeO82 is offline Find More Posts by GeO82
Old Jul 05, 2013, 12:34 PM
GeO82 is offline
Joined Jul 2012
Some footy flying with the flycam MCFC and gopro.
TheSwampFlight (11 min 30 sec)
Old Jul 16, 2013, 09:17 AM
GeO82 is offline
Joined Jul 2012
Video from some random fpv in the field with my fatshark goggles!
Field FPV with Fatshark goggles (9 min 48 sec)
Old Sep 27, 2013, 05:01 AM
Spawn32 is offline
Find More Posts by Spawn32
Norway, Vestfold, Re
Joined Sep 2013
Hi,
I have just order a Tarrot T810 and i am looking for a good controller for it, what do you guys recomend ?
I have been looking at the FlyCam MCFC Set and the MultiWii with gps and osd.
Is ther any problems with this ? witch should i go for, looing for frequent fw updates and good support.
Or ar all off you going Naza ? if so, what modell Naza is the best ?
Best Regards
Morten (Norway)
Spawn32 is offline Find More Posts by Spawn32
Old Sep 27, 2013, 06:22 AM
ikotikot is offline
Joined May 2008
Originally Posted by Spawn32 View Post
Hi,
Best Regards
Morten (Norway)
can't go wrong with the naza-m v2. avoid the headache
Old Jan 06, 2014, 07:29 PM
hamsterrorist is offline
Find More Posts by hamsterrorist
Should Know Better But Doesn't
New Zealand, Auckland
Joined Oct 2013
Having problems with my KK Blueboard/FlyCam "sandwich".
I've flashed the KK with Xcopter v2.9 XXcontrol via kkMulticopter flash tool (OSX - my usbasp isn't recognised in Windows), and the Naviboard with the 3.1 firmware. Both have (seemingly) succeeded.
I've calibrated the MAG, and connected to it via the Ground Station software. Sensors are working, but the 3D model shows an + configuration (not an X as expected).
That's when it hit me, the option to select the multirotor type is greyed out, with "UNKNOWN" showing.
Any ideas? My prior experience has been with MultiWii - which has been a breeze to setup by comparison
hamsterrorist is offline Find More Posts by hamsterrorist
Old Jan 16, 2014, 04:11 AM
goodvibes is offline
Find More Posts by goodvibes
Joined Feb 2013
Anybody here being successful with their mcfc? Mine is not. Very disappointing and frustrating to have.
goodvibes is offline Find More Posts by goodvibes
Old Dec 28, 2014, 04:34 AM
hcb is offline
hcb
Find More Posts by hcb
hcb
Joined Sep 2010
Problems with unit and support
Hello, after upgrade MFPC from V1 to V2 (also wasted almost 200USD for upgrade) I cannot set PID values to get acceptable position hold. Wrote several mails to Minsoo, he wantet my settings and now he does not reply any email. I wastet total around 500USD for that unit and not have some support.
I thing, that was my biggest mistake in RC to buy that unit. AOM is working much better, also for 500USD I can buy almost 5 units that working perfect and have continuous development.
Sorry for my report, but my experience with kkmulticopter.kr can know everybory for avoid the same mistake - buy that unit.
hcb is offline Find More Posts by hcb
