Old May 11, 2015, 07:42 PM
dante1 is offline
Find More Posts by dante1
XR-4Drone.com
dante1's Avatar
Canada, QC, Montreal
Joined May 2011
Originally Posted by elcogollobud View Post
ok,tanks!! now the swich of 3 positions (aux3 in tx) ,up land,middle FM 1 and down FM 2.
moreover;
AILE is THRO
ELEV no working
RUDD is ELEV
THRO is RUDD
Send me a pm with your email address and I have a preconfigured sketch for the Turnigy transmitter and RX.
dante1 is offline Find More Posts by dante1
Old May 11, 2015, 07:51 PM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Originally Posted by gatonini View Post
Hi
I just purchased my mirumod yesterday from ebay. I emailed the seller and asked about what settings my CT6B should be set to control the mod. He emailed me a web
page. I can make sense out of most of it but there is something about -100 +100
that I cant make sense of any help would greatly be appreciated. Thanks Gary
http://www.jgui.net/jg/ar.drone/
Which software are you using to configure your transmitter?
Old May 11, 2015, 07:57 PM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Hi
Someone a while back PM'ed me the settings for the CT6B...
From the start set Type to ACRO
Set the endpoints for channels 1-4 to 120%
Leave 5 and 6 at 100%
In the Revserve (Reverse) option, set channels 1 and 2 to reverse (ticked)
Make sure Stick is (Model 2)
On the Mix selection select Mix 1,
Source VR A
Des CH5
Up 100%
Down 100%
SW A
then (OK)
Select Mix 2
Source VR B
Dec CH6
Up 100%
Down 100%
Switch SW B
then (OK)
Then rotate the left dial (B) all the way clockwise, so it's pointing at about 2 o'clock
Rotate the right dial (A) anti clockwise, so it's pointing at about 4 o'clock.
Then set both switches pushed away.
You are now in LAND mode. Flip the right (A) switch towards you for take off in FM_1.
FLip the left (B) switch towards you for FM_2, back down for FM_1.
To land, flip the right one back away for LAND in either mode.
Need to be both pushed away (LAND + FM_1) for the mod to fully initialise (rapidly flashing LED).
Old May 12, 2015, 06:29 AM
elcogollobud is online now
Find More Posts by elcogollobud
Joined Apr 2015
already ok,tanks!
elcogollobud is online now Find More Posts by elcogollobud
Old May 12, 2015, 09:10 AM
gatonini is online now
Find More Posts by gatonini
United States, PA, California
Joined Mar 2015
CT6B and mirumod
Hey dante 1 just wanted to ask the settings you gave for the CT6B are different than the ones from the web page you gave me which ones do you trust ?
gatonini is online now Find More Posts by gatonini
Old May 12, 2015, 09:13 AM
Joined Apr 2015
hello again, raised the skech of dante1 and making any changes in the cables and the rx station.
these values are correct, AILE, ELEV, THRO, RUDD.
AUX1 (switch 3 pos), up -1000, middle 0 and down (+) 1000.
GEAR (right switch up more to me) chang -1000 to 1000
PS: and edited works that the station mode to mode 1
tanks all for help me
pd: working in ardrone!
the LED on the Arduino works (problem of diode wrong side) and managed to start the drone, but did not have much power (which I have no propeller for safety) and to stopped just a few seconds I only need to know how the modes is set flight, I still investigating
Old May 16, 2015, 02:16 PM
Joined Mar 2015
new mirumod turnigy landing procedure
Hi
i have a question got my mod today. Got it to bind with my CT6b. So I flip the A switch forward it takes off. Now heres the problem when I flip the switch to land the motors shut off and it falls hard is it suppose to do a soft landing or is this what happens ? Thanks Gary
Old May 17, 2015, 10:01 AM
Joined Mar 2015
xxx
Old May 17, 2015, 01:11 PM
dante1 is offline
XR-4Drone.com
dante1's Avatar
Joined May 2011
Hi ran into another problem went to plug a usb cable in to look at setup mode the way the mod is soldered together no way a plug will go in there any ideas ?
Can you please email me directly when you have questions like these. People here have no clue what you are talking about. Your question is very specific to the mod I built for you.
To answer your question...use a cable with a less bulky connector.
Old May 18, 2015, 04:36 AM
Joined Apr 2015
9x someone with me to spend the connection diagram arduino>rx please
tanks!
Old May 18, 2015, 06:08 AM
Fioulmaster is offline
Find More Posts by Fioulmaster
France, PCh, Poitiers
Joined Oct 2011
tanks!
For T9x , if my memory is good, the wiring is:
Ch1--Arduino Pin5
Ch2--Arduino Pin6
Ch3--Pin7
Ch4--Pin4
Ch5--Pin3
Ch6--Pin2
Fioulmaster is offline Find More Posts by Fioulmaster
Old May 18, 2015, 01:45 PM
Joined Apr 2015
Ch1--Arduino Pin5
Ch2--Arduino Pin6
Ch3--Pin7
Ch4--Pin4
Ch5--Pin3
Ch6--Pin2
okk!! tanks,will try to have such works in the hyperterminal
Old May 18, 2015, 02:46 PM
Joined Apr 2015
I've been testing, but not what function each swich, motors start up the switch to the right (in front of me) but do not stop, some easy tutorial (for Dummies) to set the landing and stopped?
thanks!!
Mini-HowTo RC Controlled AR.Drone w/o WiFi! nosaari Multirotor Talk 117 Dec 07, 2014 04:04 AM
For Sale Parrot AR Drone w/TX/RX mod *Flies Nice* Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Apr 16, 2011 09:42 PM
Discussion Wifi Boosted AR.Drone Fallengod Multirotor Talk 7 Feb 12, 2011 10:52 AM
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Sold Parrot AR.Drone Four rotor platform control with your iPodTouch/iPhone/iPad Hoverup Aircraft - Electric - Helis (FS/W) 0 Oct 12, 2010 03:54 PM
