May 17, 2013, 02:01 PM
United States, IL, Addison
Joined Jan 2012
Originally Posted by helikido
There is an issue iI'm having though. I get allot of bogging on flips and I always scramble after a flip. Pitch curve is -30 to 30 on the tx and throttle curve is 100-80-100.
Also I noticed that almost after one minute of flightime, the power becomes slugish a bit, which is really annoying. I don't know if I have too much pitch for this heli or the throttle curve is not good. I fly idle up only so yep.
Does the motor get way too hot after a full flight?
I've spent a lot of money trying to make brushed motors work. Once I converted to brushless, the frustration stopped. You get the longest and most consistent flight times with a brushless motor & an 8 tooth pinion.
To convert to brushless, you need a WK-WST-10A-LT, a C05M motor, an 8 tooth pinion, and a Genius CP main gear.
I don't fly stunt, so I use a 7 tooth pinion. My motor is over 9 months old, and it still flies my Genius.
