Old Apr 06, 2013, 09:44 PM
United States, NJ, Jefferson
Joined Mar 2013
Help!
AR600 Reciever in Blade 450x or 300x??
If i buy a Blade 400x or 300x without the beast x system, can i put this reciever in it? i have it laying around and i am really wondering, thanks!!
mguido6 is offline Find More Posts by mguido6
Old Apr 07, 2013, 03:05 AM
United States, CA, Irvine
Joined Sep 2011
You need a fbl controller such as beastx, ar7200bx, v-bar. Cheaper alternatives such as tarot xzy, copterx fbl and others are possible. You can't just put in a receiver and expect it to fly.
If your intention is to just put in a receiver then you need to get a flybar version like a blade 400, blade 450 3d or other similar configuration
nartac is online now Find More Posts by nartac
Old Apr 07, 2013, 11:57 AM
Joined Mar 2013
will the cheaper alternatives you mentioned bind to a spektrum radio? thanks
Old Apr 17, 2013, 09:08 PM
United States, CA, Sacramento
Joined Apr 2013
A 400 and or 450 blade head with shaft will go right in.
In fact you may not even have to adjust the servo linkages but check them anyway.
dsmx/dsm2 electronics are all interchangeable except for the external SAT links.
You should match those.....example........dsmx rx=dsmx external SAT. dsm2 rx=dsm2 external SAT.
External dsmx satalite receivers will have an (X) embedded/molded on them. Anything else will be dsm2.
If you have any tech questions we are always here to help............
smogboy7173 is offline Find More Posts by smogboy7173
Old Apr 17, 2013, 09:17 PM
Joined Mar 2013
So does this mean i can use the reciever for a flybarless heli? Thanks
Old Apr 17, 2013, 09:51 PM
Bugger, i broke it again!
Australia, VIC, Shepparton
Joined Jun 2011
Only if you also purchase an FBL controller such as a Tarot ZYX.
The receiver itself has no gyro and neither does the heli at this point. So youll need a 3axis gyro for the flybarless head. Your current receiver can be used in conjunction with a 3axis gyro.
Adge82 is offline Find More Posts by Adge82
Old Apr 17, 2013, 10:21 PM
Joined Apr 2013
no.
The fbl head must be used with a fbl controller.
If you use a 6100/6100e rx it will work with a head with a fly bar.
You will also need a gyro to control the tail,g110,g210,gy401 for example for gyros.
FBL head=FBL controller.
FLYBAR HEAD=6100/e=separate gyro.
To prevent any confusion PM me with exactly what you have and I can explain the different combinations that would work for you.
Old Apr 17, 2013, 11:49 PM
Joined Jun 2011
no.
Im not entirley familiar with the spektrum stuff, but i was under the impression you could plug any 6ch receiver into your FBL controller. Only a couple of FBL controllers have built in receivers as far as im aware.
Old Apr 20, 2013, 06:00 PM
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
no.
This is true reguarding smaller helicopters. With 550 and above, you can dial back expo and d/r enough to fly fbl w/o estab. Mind you that it will fly like a real heli in that you have to constantly apply forward and right cyclic to maintain attitude and the controls will be incredibly sensitive.
Running weighted rotors and lower rpm help with this as well.
phoenixheli is offline Find More Posts by phoenixheli
Old Apr 25, 2013, 11:44 AM
Never trust laughing dolphins
Joined Feb 2011
This is not entirely true, except for multirotor setups actually.
A two-bladed heli might hover well, but it won't fly nearly as well as it could with a flybar or fbl controller, especially flown in faster forward flight. The expo is not the problem. The pretty big lack of general stability is. Technically, anything goes, but at what cost?
PHMX is offline Find More Posts by PHMX
Old Apr 27, 2013, 02:20 AM
My other addiction!
norcalheli's Avatar
Marysville, Ca., US
Joined Jan 2007
Interesting that Vario owners have been doing it for years.
norcalheli is online now Find More Posts by norcalheli
Question Next heli after a Blade Nano CP X? Blade 300X? 450 3D? 450X? Arycon Mini Helis 15 Jun 28, 2013 11:41 PM
Wanted Wanted blade 300x or 450x rhodestimm Aircraft - Electric - Helis (FS/W) 8 Jan 24, 2013 03:21 PM
Question Blade 450x Or blade 300x? TMAC4123 Mini Helis 11 Dec 26, 2012 11:59 AM
Found Eflite Blade 300x Or 450X boatdoc Aircraft - Electric - Helis (FS/W) 4 Sep 15, 2012 11:58 AM
Link Blade 300x & Blade 450x side by side comparison Diesel6401 Electric Heli Talk 3 Jul 26, 2012 07:15 PM
