Old Dec 20, 2012, 08:07 PM
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Build Log
Freewing ME262 builds, mods, and everything else
As everyone following the other two FW ME262 (same poster) thread knows it was just released by rc-castle and BH is still has it on pre-order. I've ordered my kit from RC-Castle and it should be here by end of next wk or wk after. I will do a slow build with the 1st part being the dynam me262 canopy mod, if it fits. Everyone else is welcome to join in on their builds and mods. I'm just trying to get one thread going that everyone can come to for info, specs, mods & more, since ppl keep posting on both threads (which are the same). I'll post pics as soon as she shows up. Can't wait!!!!
PNP & Kit versions avail RC-castle, BH, Ready2fly
Manual PDF
http://rc-castle.com/images/Me262%20User%20Manual.pdf
Feature:
- Scale & High Performance Electric Ducted Fan Jet
- With Pilot Figure Include.
- With Detachable Main Wing For Easy Transport.
- With High Performance 70mm EDF Power Unit For 6S x 2 Installed.
- With 4 x 9g & 4 x 17g Servo Installed
- With Electric Retract & Metal Suspemsion Strut.
- With Flap System Installed.
Specification:
- Material: EPO
- Wingspan : 1500mm ( 59.0in )
- Length : 1,280mm ( 50.4in )
- Flying weight: 2,900g
- Static Thrust: 2,850g
- Servo: 4 x 9g Servo & 4 x 17g Servo (Include & Installed)
- Landing Gear : Electric Retract Landing Gear With Metal Suspension Strut (Include & Installed)
- Ducted Fan: 70mm Ducted Fan , 6 Blade x 2 (Installed)
- Motor: 2849 2300Kv Brushless Motor x 2 (Installed)
- ESC: 55A Brushless ESC x 2 (Installed)
- Battery: 22.2v 3700mAh 25 - 30C (Not Include)
- Radio: 6 - 9Ch (Not Include)
Kit
http://rc-castle.com/shop/product_in...oducts_id=2900
http://www.bananahobby.com/messersch...1713-prd1.html
PNP
http://rc-castle.com/shop/product_in...oducts_id=2899
http://www.bananahobby.com/messersch...1712-prd1.html
v8truckin is online now Find More Posts by v8truckin
Old Dec 20, 2012, 09:47 PM
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
I just ordered a Dynam canopy just in case I get a Freewing 262 some day. If the canopy fits they will sell out fast.
merlinfan is offline Find More Posts by merlinfan
Old Dec 20, 2012, 09:54 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Ya I hear ya on that. Its a 50/50 , but hey what do we got to lose.
Old Dec 20, 2012, 10:12 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Here will be my setups depending on what preforms better during static test.
FW 2300kv motors & FW fan (have a spare set sitting in closet from SU35)
Or
FW 2300kv motor & CS10 ( depending on thrust vs stock FW blades)
Or
Cyclone Power 2500kv motors & stock FW fans
Like I said I will test all 3 setups to see which preforms better as I have all parts avail.
80a x 2 HW escs
20a cc bec pro or 10a cc bec, depending on room. (both sitting in closet also)
Electric brake system (Tornado brakes)
TP90MG - Aileron servos & steering
HS82MG - elevator servos
Remainder servos stock FW servos
Old Dec 20, 2012, 10:27 PM
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Mesa
Joined Mar 2009
I'm in, thanks for the pm V8, Pete told me last week they were in CA, and clearing port customs and should be shipping out soon....I'll wait since I got it when it was $349 shipped as an ARF. Will probably be here shortly after the first. And besides we are in the middle of a Move to a new house till then, so I will be able to set up shop in the garage finally.
Planes start getting moved over tomarrow
brandonmoon is offline Find More Posts by brandonmoon
Old Dec 20, 2012, 10:53 PM
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Pictures?! Stats.... and stuff?
Maxthrottle is online now Find More Posts by Maxthrottle
Latest blog entry: Freewing 90mm F-16C
Old Dec 20, 2012, 11:45 PM
genghiskt's Avatar
Joined Sep 2011
Or
Or
80a x 2 HW escs
V8,
The kit does come with the fan, so you will have another spare set!!
I ordered mine kit with servos, I hate going thru all the servos wires. Either too short or too long.
I should be getting mine the week after next. And I have two different Kv motors coming too... 1800Kv and 1950Kv inrunner. Will try on 8s setup on the stock fan.
Let's hope it fly well..
genghiskt is offline Find More Posts by genghiskt
Old Dec 21, 2012, 12:56 AM
Joined Jun 2012
What 1950KV motors are those... I think a 1950kv motor would be perfect for a twin cs10 setup
PAPE is offline Find More Posts by PAPE
Old Dec 21, 2012, 02:04 AM
Vienna, Austria
Joined Apr 2007
beware when using different rotors
if I read correctly the fans are counter-rotating
that means that the vanes of one shroud will be tilted in the "other" direction.
otherwise you could just put in 10-blade (the newer 12-blades might also fit, but tightly).
as it is, you will have to replace one fan shroud
not expensive, HK has them I think...
(pre-ordered mine from ready2fly, plan a low power 4s setup using stock 2300kV motors with Change Sun 10-blade rotors. mine will be light w/out retracts and light lipos, so I hope power will be sufficient)
mopetista is offline Find More Posts by mopetista
Old Dec 21, 2012, 02:12 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Ya know I never thought about that when I installed my cs10 in my su35. I used the stock shrouds , stock motor and cs10 fans and did notice thrust wasn't up to par. Maybe that was a reason thrust was low. Thanks I'll keep that in mind and will also re-test my su35.
Originally Posted by genghiskt View Post
V8,
G, ya luckily my field has very lil FOD so my fan blades last awhile, but ya its always nice to have spare fans. You order from RC-castle?
Old Dec 21, 2012, 02:53 AM
genghiskt's Avatar
Joined Sep 2011
V8,
Nope, I didn't get it from there. Mine is on the ship now.
CS10 doesn't preform well in Freewing shroud. CS10 get higher number in the CS10 shroud. For the freewing counter fan, if you put in the wrong rotation rotor you only get half the performance.. So far these are what I experiences.
I m trying to run the stock fan to 48k rpm. Wish me good luck !
Pape, these motors are custom made. Will test it out first.
Old Dec 21, 2012, 03:10 AM
Joined Jun 2012
custom made inrunners... sounds expensive. keep us updated on them.
Old Dec 21, 2012, 03:13 AM
Vienna, Austria
Joined Apr 2007
CS70 10-blade rotors in Freewing shroud
Have't tried it myself but on the CS70 thread is has been claimed to work well (I voiced the suspicion that there was too much clearance between blades and shroud).
However, not a bad thing since the new 12-bladers are slightly bigger, that might work better then without sanding them down.
Looks like the 12-blades are replacing the 10-blades totally at Change Sun anyway...
check the tilt of the vanes, if they're built for counter-rotating fan rotors, you will dramatically increase the swirl (instead of elimininating it), and the losses will be dramatic (probably not 50% though)
Old Dec 21, 2012, 07:05 AM
genghiskt's Avatar
Joined Sep 2011
Better keep some stocks for the CS10. CS12, I tested it briefly I don't see any gain in performance but amp draw up by about 10%. To me, I will stick with CS10.
Yes, Changsun is stopping CS10. Future will be only CS12. If CS12 can run at higher rpm it is a bad thing. 8s should be interesting.
Old Dec 21, 2012, 08:31 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Well it would be nice if they did do CR fans on the CS10/12.
Ya my power loss was about 25% on the SU35 w/ CS10 in FW shroud, makes sense now.
Poll Dynam ME262 VS. Freewing ME262 Forrest Gump 23 Nitro Planes 26 May 30, 2014 08:33 PM
Build Log FreeWing F6F Hellcat build & 90 Degree Rotating Retract Mod Orion Pax Electric Warbirds 298 Jul 13, 2013 04:31 PM
Discussion DIY battery packs for everything else kenstogie DIY Electronics 7 Sep 06, 2012 04:07 PM
For Sale GWS Me262 new in box with almost everything you need-giving it away for $99+ !!! shooboy Aircraft - Electric - Jets (FS/W) 6 Sep 06, 2012 11:52 AM
Sold Pulse XT 25e and everything else. Matt1724 Aircraft - Electric - Airplanes (FS/W) 1 Mar 24, 2012 07:59 PM
