Old Jul 22, 2012, 11:08 AM
Dornbirn / Austria
Joined Mar 2008
Variometer suggestions?
Hi there,
I'm looking for a Vario that I can use in a normal glider (non fpv) and also one that
I can use for FPV.
Ideally it would be audio, not only video overlay and lightweight for the standalone, non-fpv planes.
So far I had a look at:
- Frsky Vario (as I want to try frsky for telemtry anyway once) but this doesn't support audio I think
- http://www.lastonedown.com - audio but needs FPV equipment
For lastonedown I could use very basic equipment (without camera?) I guess to use with my normal, non-fpv gliders.. does anyone know it's weight?
What would you suggest? Any recommendations?
Thanks a lot,
Christoph
solars is offline Find More Posts by solars
Old Jul 22, 2012, 12:13 PM
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
I use the Thermal Scout by Winged Shadow Systems on my FPV sailplane and it works great. Its audio and can be set to signal lift or lift & sink. Can be turned on/off from the radio. You do have to add your own ear bud style speaker and I have mine mounted right next to the on-board mic. For non-FPV use it can also be set up to wag the rudder to signal lift.
Originally Posted by solars View Post
Hi there,
I can use for FPV.
Thanks a lot,
Christoph
Gary Evans is offline Find More Posts by Gary Evans
Old Jul 23, 2012, 02:47 AM
Joined Apr 2011
I've got the thermal scout too. For its price and size its great
brucey is offline Find More Posts by brucey
Old Jul 23, 2012, 05:10 AM
pitlab's Avatar
Warsaw, Poland
I'm looking for a Vario that I can use in a normal glider (non fpv) and also one that I can use for FPV.
Hello Chrstoph
I could recommend the SkyAssistant variometer.
It is standalone device, work with any LPD/PMR radio, can speak messages in your language and with little modification can be connected it to FPV system in future.
pitlab is offline Find More Posts by pitlab
Old Jul 24, 2012, 05:28 AM
Dornbirn / Austria
Joined Mar 2008
Thanks a lot for your suggestions! Those products look quite interesting
Does anyone know the weight of the lastonedown and skyassistant?
Old Jul 24, 2012, 05:08 PM
pitlab's Avatar
Warsaw, Poland
Weight of SkyAssistant is 22g
Old Jul 24, 2012, 07:43 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Could combine L1D with one of fmkit's UHF beacons, which can
be set to transmit audio continuously, which can then be picked up by any
FRS handheld radio on the 460Mhz band.
ian
Daemon is online now Find More Posts by Daemon
Old Sep 04, 2012, 06:40 PM
Joined Sep 2012
Are there any more suggestions? I'm very interesting about this thing. Thank you
Miloss is offline Find More Posts by Miloss
Discussion Open source speaking height/speed/variometer kapteinkuk Sailplane Talk 13 Nov 24, 2012 08:52 PM
Sold $290 Eagle Tree Seagull Glide Variometer 900MHz System tdecker51 Aircraft - Sailplanes (FS/W) 1 Jul 15, 2012 05:37 PM
Discussion Thermal Scout by Winded Shadow System tone variometer not103 FPV Talk 19 May 10, 2012 02:21 AM
Idea Request: Visual Variometer on Altitude Ladder MikeD096 Eagle Tree Systems 9 Mar 30, 2012 02:53 PM
Discussion Need your opinion on mechanical variometer GreenAce92_v2 Sailplane Talk 7 Mar 16, 2012 11:57 PM
