Old Mar 14, 2011, 03:00 PM
Turkey - Istanbul
Joined Jun 2009
Can never find propeller for my ARPRO EP 700, please help !
Can you please helşp me about this, i can not use my boat for a long time, i bought it here from a model shop, they also dont sell replacement parts for the boat
Please help, thanks...
beachbumbora is offline Find More Posts by beachbumbora
Old Mar 14, 2011, 04:18 PM
siberianhusky's Avatar
Canada, ON, Peterborough
Joined Nov 2009
Just about any on line hobby shop should be able to set you up, Offshore electrics is a good one.
You won't find a specific prop for your boat, you will be buying something aftermarket from Octura, ABC,Prather, grim racer etc.
If you know the diameter and pitch of the original you should be able to find something really close to it aftermarket.
Is it a 3/16 shaft or 4mm? In N.A. we don't see much of the metric stuff, but I think Graupner has a line of metric shaft props. Or you could use an adapter or ream the prop out to fit the shaft depending on the size.
siberianhusky is offline Find More Posts by siberianhusky
Old Mar 14, 2011, 04:41 PM
Closed Account
Joined Jul 2006
arpro 1
Offshore electrics.com has carbon fiber props-34.5mm-36mm-also " K " like Like Mr. Pompebleb mentioned. Look for carbon props 2317.40=40mm and etc. I'm not trying to out due Mr. Pompebled, just adding to his post. He's areal gentleman in my books!!!! I see Istanbul- i wonder if Germany or U.K. at Aztec hobbies can help as they would be closer to your area. Just a suggestion only. I also have a Arpro 1 with a 36 40 05 3900 Turnigy motor and placed motor stem 4" ( 100mm ) from transom and use flex cable and extended the rudder 1" ( 25mm ) to match the dog drive. Have a good day! Yes, i know, i talk to much!
Mikedown is offline Find More Posts by Mikedown
Old Mar 14, 2011, 06:19 PM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi BB,
The stock props are plastic and not very strong, I shortened the propshaft on my ARPRO on the motor side, so I could add a washer and a nut.
This way I was able to run the Graupner 2318.xx K-series props which are much stronger and last longer.
If you run the stock 1520KV outrunner on 3S, you can go as big as a 45K prop, start with a 40,5K to be on the safe side and check the temperature regulary when testing new(bigger) props.
Finding a source for the K-series props can be a problem, try eBay.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Mar 14, 2011, 08:55 PM
Turkey - Istanbul
Joined Jun 2009
siberianhusky, retoabcr and pompebled thank you all.
i still dont know really what to do, i searched ebay and found nothing at all. maybe i must learn its dimensions as you wrote and look for similar propellers...
Old Mar 15, 2011, 03:55 PM
United Kingdom, Garstang
Joined Nov 2009
Hi beach
If your ARPRO is standard then you need a drive dog 4mm P1.4 prop.
you want either :-
1.
http://cgi.ebay.co.uk/PROPELLER-X438...item1c1a093d26
OR
2.
http://cgi.ebay.co.uk/PROP-ADAPTER-3...item230efb0364
AND
http://cornwallmodelboats.co.uk/acat...lers_2317.html
or you could go :-
3.
http://www.storacingproducts.com/spa...at-spares.html
if you go #3 make sure you buy a few they'll shatter.
Hope that helps
richardknox is offline Find More Posts by richardknox
Old Mar 17, 2011, 02:02 PM
Turkey - Istanbul
Joined Jun 2009
Originally Posted by richardknox View Post
Hi beach
you want either :-
1.
OR
2.
AND
or you could go :-
3.
Hope that helps
Hello richardknox !
Thanks so much ! My arpro is the one pink color, 700 ep.
I wanna buy the bronze one, but do i have to buy the adapter also ? I couldnt understand that, thanks again !
Old Mar 17, 2011, 03:24 PM
Joined Nov 2009
Beach
Most drive dog type props are 3/16" which is slightly bigger than 4mm which is on your ARPRO. You slide adapter in to the prop which shims it up.
I seem to remember my ARPRO ran best on an octura X442. PMB do them, balanced and sharpend for around 15 + post.
A good upgrade for the ARPRO is
http://cgi.ebay.co.uk/RCS-Water-Cool...item3f03e4d492
Just get yourself a 5000mah battery, and you've got a quick boat.
Old Mar 17, 2011, 09:02 PM
Turkey - Istanbul
Joined Jun 2009
Beach
wow, amazing things you re talking about but it is so bad that i dont understand much about upgrades
first i buy the propeller and the adapter, and the motor after that ( is it easy to change the motor ? ) and finally a 5000 mah battery ( will it fit in the boat ? wont it be so heavy ? and when i put it on the left how will i balance the boat ? )
thank you so much and sorry to take your time...
Old Mar 17, 2011, 10:25 PM
Closed Account
Joined Jul 2006
Arpro 1
Istanbul; remember the pictures of the original A 1 where the lipo was setup with battery on the left. The boat straightens out once you pull the trigger. The weight difference btween 5000 and 4000 isn't enough to make any difference. Whats missing here is you have torque roll to the right to start off with and the lipo is on the left so it balances itself out when under way. Also when you setup a mono that you have built or revamped, the strut must be set so it veers to the right to combat the torque roll even with duo batteries ; one on each sie of the motor.This distance is about 3/16" of an ". Now if i remember Ferral of Australia revamped his Arpro 1 by placing his motor way up front and placing his duo lipos toward the rear and alittle to the left to combat the torque roll. You figure, just a 1/2" of both toward the left is enough weight to do the job.
Discussion Please help me with my quadcopter's propeller and motor selection shadow511 Electric Motor Design and Construction 2 Mar 10, 2011 10:49 PM
Discussion Can not find lightweight retractable gear, please advise dtrip Beginner Training Area (Aircraft-Electric) 3 Feb 21, 2011 04:30 PM
Discussion Just got my cx2, can't find blue accessories for it... Jlomb436 Coaxial Helicopters 10 Oct 18, 2010 11:08 PM
Help! Please help me find an old model decal; "Checkerboard lady"? Aten W Arthog Electric Plane Talk 6 Oct 08, 2010 12:01 AM
Help to find an inexpensive gyro for my EP concept. gixxer Electric Heli Talk 11 Nov 22, 2002 08:20 PM
