Old Dec 28, 2010, 09:53 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Battery Backer - second battery back-up
Years ago in UK - a company came up with the Battery Backer ... a simple small box that you could feed your Rx battery through. A second small pack could be connected as well so in event that first main pack failed - you had the second one immediately click in to keep you flying and land.
Nowadays we read about BEC's on ESC's failing if pushed by number of servos, hard flying etc.
Has anyone used such a backer in these times ? The weight is only 35gr
(sorry about the photo - but my main digi camera is in my bags lost by the airline on my return few days ago ... )
I'm seriously considering fitting it to my machine - not that I have problems, but as a safeguard ....
Can anyone think of a reason it would not work ?
solentlife is offline Find More Posts by solentlife
Old Dec 28, 2010, 10:58 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
There are many such devices and arangements used howerver this really is more of a Rdio question and IMO belongs here
http://www.rcgroups.com/radios-135/
Old Dec 28, 2010, 11:06 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Doing a search on "Battery Backer" finds some discussion. Primarily used in large scale planes and sailplanes. Doesn't look very widely used but when ya need one, it might be a good idea to prevent the loss of a high $$ aircraft.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Dec 28, 2010, 12:05 PM
solentlife's Avatar
Joined Jan 2010
Each to their own ... It sits on the dividing line IMHO. It is neither more "radio" forum than this one ....
If you are a Moderator ... which I don't think you are ... then it's only your opinion ... and it's up to a Mod to move it if they feel so inclined.
Does it REALLY matter ??
Old Dec 28, 2010, 12:09 PM
solentlife's Avatar
Joined Jan 2010
mw
In the 80's when NiCD's were usually 500mAH and to get more capacity meant a large heavy pack - these were used to add a small 150 - 250mAH pack behind.
Yes - mostly used by larger models especially in the early days of LMA rules being compiled.
I have it sitting here and it occurred to me as I also have the 250mAH pack ...
Now the question is can the "Backer" work with an ESC"s BEC ... as it's designed for nominal 4.8v packs ..... ?
Old Dec 29, 2010, 05:15 AM
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
I use a backer in my large electric models, having almost been bitten once. What I do is use an appropriate BEC device as one input to it and a receiver pack of some sort as the other supply. These days, I tend to favour 2 x A123 cells for the Rx pack.
GordonTarling is offline Find More Posts by GordonTarling
Old Dec 29, 2010, 12:14 PM
solentlife's Avatar
Joined Jan 2010
Excellent ... that's what I was hoping to hear ... that ESC through one is OK ... and I was considering my 250mAH light pack as back-up - which would give me more than enough to do circuits to land.
Old Dec 30, 2010, 01:51 PM
Joined Mar 2001
You need to be sure that you keep all voltages and currents within the specifications of your battery backer. Also, you need some device that enables you to check the state of your backup pack before each flight - no good taking off with one that's flat!
Old Dec 30, 2010, 06:34 PM
Melbourne, Australia
Joined May 2006
Is it anything more than a couple of plugs/sockets and diodes?
kgfly is offline Find More Posts by kgfly
Old Dec 31, 2010, 08:22 AM
Joined Mar 2001
Those that I use are Powerboxes, so they are a bit more than 'a couple of plugs/sockets and diodes', as you put it. I know many people will say to keep it simple and that a Powerbox is just another thing to go wrong, but I've had no problems with what I use and like the extra facilities that these offer. There's plenty of choice out there if you look in the right places.
Discussion ce osd second battery connection borsel FPV Talk 3 Nov 25, 2010 02:39 AM
Discussion Back up reciever battery n2soaring Beginner Training Area (Aircraft-Electric) 5 Sep 17, 2010 12:39 PM
Help! AW-2 Battery backer seanpcola Sailplane Talk 7 Mar 19, 2008 01:36 PM
Question RX-9 SYNTH DS IPD "battery backer" emersunn Hitec/Multiplex USA 1 Apr 22, 2005 03:29 PM
Jomar Battery Backer NIP with 12" lead Steve H. Aircraft - General - Radio Equipment (FS/W) 1 Jan 25, 2005 09:11 PM
