Old Jul 18, 2013, 10:23 PM
RCGwhinerFest is offline
Find More Posts by RCGwhinerFest
NCSS, Slopeflicker
Joined Jun 2013
9C setup for the acacia 2 anyone?
Hello all!
I have a program for a full house with aileron to flap mixing for another plane. Works Great!
However the acacia only gets about 2 degrees of reflex in flaps and full travel down, and I have been at my wits end trying to figure out how to get the full camber changing, and elev to flap/ail.
Naturally I need full throw crow as well. you know....all that stuff.
I was surprised to find that it didn't have full span aileron function but It's the plane I have.
Programming the radio always makes me feel thick as a brick.
Any assistance is much appreciated.
Scott
RCGwhinerFest is offline Find More Posts by RCGwhinerFest
Old Jul 18, 2013, 10:44 PM
concreteman is online now
Find More Posts by concreteman
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
Scott, i used the 9c for a few season. They work well, but programming is quite slow. You can get to everything you need, be patient. Using programmable mixes, you will need to do elevator-flap, then elevator-ail1, and same for elevator-ail2. That gets you snapflap, try about 4mm at full pull. Mix aileron-flap, yes. I think you can make that active in "normal" mode only, and keep it not functional in "landing" mode. Landing mode will need down elevator mixed to flap. Trying to remember how to do trailing edge camber...
Ahh, memories...
WD
concreteman is online now Find More Posts by concreteman
Discussion Anyone flying a Blade Nano CP X on a Futaba 8U or 9C? rcav8or Electric Heli Talk 1 Aug 13, 2013 06:18 PM
Sold Custom FPV Setups for Anyone DJO FPV Equipment (FS/W) 5 Feb 04, 2013 05:51 PM
Sold Custom FPV Setups for Anyone DJO FPV Equipment (FS/W) 0 Jan 26, 2013 05:42 PM
Help! Wanted: Acacia 2 wing joiner Gonesoaring2003 Multi Task F3X 3 Jan 25, 2013 01:27 PM
Discussion Anyone got settings for a King 2 with 2.4gHz T6EX radio for 3D setup please? turnbui Micro Helis 0 Jun 13, 2009 06:00 PM
