Old Oct 14, 2012, 06:22 PM
gin85 is offline
Find More Posts by gin85
Joined Sep 2012
Best 4 ch. Trainer for beginner
Ready to go to a good trainer4 ch radio plane. I have a spectum dx6i on the way. I will need an airplane that can bind with my spectum. I also have a grass airstrip. This was hard on my 3 ch. Setup. Any and all suggestions would be appreciated
gin85 is offline Find More Posts by gin85
Old Oct 14, 2012, 09:30 PM
MX5Seeker is offline
Find More Posts by MX5Seeker
Glad to be here...
MX5Seeker's Avatar
United States, GA, Cleveland
Joined Feb 2012
Get an Apprentice. Change to larger wheels for the grass. It's a great 4 channel trainer, large enough to see easily at a distance. And can be used for some simple aerobatics, like inverted flying.
MX5Seeker is offline Find More Posts by MX5Seeker
Old Oct 14, 2012, 11:29 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
hawksy at nitroplanes.com or bixler or sky surfer
fastfwd is offline Find More Posts by fastfwd
Old Oct 15, 2012, 04:37 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Convert your existing 3ch machine to 4ch. I did this a lot before when I used to teach flyers ... literally soon after first flights - I showed them how to modify their trainer to 4ch ...
That way they had a familiar model but added benefit of 4ch.
How ?
a) Cut wing at centreline and reduce dihedral to less but NOT zero. We can leave a sensible amount to still give some aspect of self-levelling. Usually you can remove about half the dihedral. Reglue the wing together with short bamboo skewers (2) across joint.
b) Cut trailing edge of wing either side to create ailerons. Leave centre section intact ...bevel front edge of ailerons so they can deflect up / down ...
c) Hinge to main wing using mylar strip or hinges.
d) Set small servo into each wing with short control rod to horn on each aileron.
e) Use Y lead to connect servos to Rx in primary turn channel (ie where you used to have rudder)
f) Plug rudder servo into secondary turn ch usually ch 4 on most Rx's.
Set all up level ... make sure you have reasonable travel on ailerons ... and set dual rate ailerons at 50 - 60% of that just in case.
Deep breath ... go fly.
If it's anything like the guys I showed to do above - you'll be amazed what your old trainer can now do. Keep on with it while looking at the 4ch or better that you want to have ...
Nigel
solentlife is online now Find More Posts by solentlife
Old Oct 15, 2012, 06:41 AM
eagle1933 is offline
Find More Posts by eagle1933
Dallas USA, TX
Joined Jul 2010
+1 fastfwd. (1) Hawk Sky - Nitroplanes, (2)Bixler - Hobby King or (3) HobbyZone Champ.
The Champ is only three channels but a terrific plane to learn on. There is a huge thread on this forum dedicated to the Champ.
eagle1933 is offline Find More Posts by eagle1933
Old Oct 15, 2012, 06:51 AM
dmcMaine is offline
Find More Posts by dmcMaine
United States, ME, West Bath
Joined Sep 2012
I don't know if its the "best", but the Flyzone Sensei has received some very good reviews. Plus it has drop doors.
dmcMaine is offline Find More Posts by dmcMaine
Old Oct 15, 2012, 08:52 AM
solentlife's Avatar
Joined Jan 2010
As I read it - he's done the 3ch route and now wants to move on and up a grade .. surely all the quotes are basic level trainer planes whether 3 or 4ch ? My impression is he wants an intermediate level trainer.
In fact if OP can already fly the 3ch ... then I would say go for a Skyartec Cessna 182 or similar .......
But I may be missing something in his original post ?
Nigel
Old Oct 15, 2012, 09:08 AM
Gavinxman is offline
Find More Posts by Gavinxman
Gavinxman's Avatar
Joined Aug 2011
E flight T28 !!! IMHO it's the best 4ch for new pilots . I got the super cub dsm as my 1st plane and there great !!! Hands down easiest plane to learn with but after 2 weeks I was boarded with it and got the T28 and I'm still loving it . But have since moved on to ordering my 1st balsa like a big dummy lolo . You'll love the T28 by e flight and get the pnp if you have the dx6i . Good luck
Gavinxman is offline Find More Posts by Gavinxman
Old Oct 15, 2012, 10:25 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
If you want a low cost 4 channel trainer, check out the Ares Gamma 370. It comes as either a 3 channel RTF or a 3 channel Rx-R. Get the Rx-R and install the optional $30.00 aileron wing. You will then have a 4 channel trainer for around $110.00. later on you can get the brushless power setup for an additonal $40.00. Actually the E-Flight T-28 Trojan is a Parkzone model. It is also an excellent first 4 channel plane as are the Flyzone Sensei and E-Flight Apprentice. I recommend the Gamma 370 though because of the value for the price.
chucksolo69 is offline Find More Posts by chucksolo69
Old Oct 15, 2012, 02:00 PM
solentlife's Avatar
Joined Jan 2010
I am always surprised by price quotes and what you get for money ...
I'm a real skinflint cheapo ... and paying over $100 for a trainer ?
My Cessna 182 from Skyartec as a Plug and Fly ... all I did was plug in my Rx and add a 3S battery ... was $60 + shipping. It has 5ch in fact as it has flaps but there's no need to use if you don't want. But ALL are ready linked up with good budget servos ...
I fly EDF's slopers, gliders, biplanes, pushers, literally anything that has wings ! including helis .. the Cessna is my model that is ALWAYS in the car ... and I've handed the Tx over to newcomers to the hobby and they found it a good follow on from their basic model.
But I'm biased as I own one !!
Nigel
Old Oct 15, 2012, 02:59 PM
Joined Apr 2011
I don't recommend cheap airplanes with no customer support for a newbie. The planes I recommend to beginners are going to have the best CS and parts support. You just don't get that with the Skyartec stuff from Banana Hobby or NitroPlanes, or even HobbyKing for that matter, over here. You may have had a good expericence in Latvia, but here in the states it is another story. As for being a skinflint and el cheapo, that may be you, but not everyone thinks that way. I know I don't. Price is relative, after all.
Old Oct 15, 2012, 07:27 PM
nforbesrc99 is offline
Find More Posts by nforbesrc99
Jet guy w/ no money to buy jet
nforbesrc99's Avatar
United States, GA
Joined Jul 2012
That thing is way too fast for a beginner!!!! I flew one and I was shocked! But its fun LOL.
I'd recommend the eflite apprentice, easy, forgiving and awesome. If you have a dx6i than get the apprentice PNP get a AR600 RX and a Turnigy 3600mah 3s 25c. Also get the hobbypartz Thunder AC6 charger. I have one and I love it.
nforbesrc99 is offline Find More Posts by nforbesrc99
Old Oct 15, 2012, 11:12 PM
IWC is offline
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
chucksolo, where do I buy a Gamma 370 from?
IWC is offline Find More Posts by IWC
Old Oct 15, 2012, 11:42 PM
solentlife's Avatar
Joined Jan 2010
The Skinflint / cheapo bit was a joke .. but had a side that I don't understand why some advise models that are overpriced.
As to Skyartec ... they have a good online site and deal direct for all parts ... they can be talked to and respond very well.
http://www.skyartec.com/Product.asp?BigClassName=Spare parts
I know they also have affiliate outlets in various countries ... UK I know and there is most likely a USA as well ...
You may consider price relative - but in fact Skyartec are providing good quality models at very good prices. If you think that paying a higher price guarantees better product - then sadly you are often wrong. That is not how the world works today. Price is often set at what the manufacturer thinks he can screw out of you.
So before knocking such as Skyartec as you have done - a little research would have shown the error.
I have had good back-up from them, it has survived all I throw at it in near 2 years, parts are readily available albeit by post and at budget prices as well.
Nigel
Old Oct 16, 2012, 02:43 AM
Tony K is offline
Find More Posts by Tony K
United States, MI, Monroe
Joined Jun 2009
The park zone T-28, a good 4 channel plane for sure.
Tony K is offline Find More Posts by Tony K
Discussion 4 CH Freewing Spirit RC Trainer Airplane NorCal Foamies (Kits) 13 Dec 04, 2012 01:12 PM
Discussion Any suggestions for a 4-CH beginner FP heli? singingstrings Beginner Training Area (Heli-Electric) 9 Apr 12, 2012 11:38 AM
Discussion What is best beginner 4 ch for large front yard - waiting for club training tag1859 Beginner Training Area (Aircraft-Electric) 11 Mar 08, 2012 06:44 PM
Discussion 4 ch vs. 6ch heli for beginners FearDearg Electric Heli Talk 27 Dec 06, 2010 07:10 AM
Best 3d Foam Trainer For Someone Who Is A Beginner In 3d agapornis 3D Flying 4 May 11, 2005 07:29 AM
