Old Dec 29, 2010, 12:36 PM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
Question
3421 vs 94820
I have been thinking about trying the Airtronics 94820 when I need another 3421.. They are just about 1/2 the price. Very close in size and weight..Any one try the 94820s? Any comments? Brian
BrianSmith is offline Find More Posts by BrianSmith
Old Dec 29, 2010, 01:50 PM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Brian, they are FANTASTIC servos. Compared to the 3421, they are a touch slower, but a touch more powerful when you compare the specs. For a long time, the 3421 was my favorite servo. I say this as an Airtronics team pilot, so you know I shoot straight. That being said, I don't use them anymore. They are a bit too expensive and too thick. There are too many other great choices.
I used to use them in the fuse for my tail servos. They are still an awesome choice. But they are too strong, so I choose a faster, smaller servo. Hopefully a cheaper one too. For the longest time they were my absolute servo of choice for the flaps in my large TD ships, and my B planes if I could fit them. There is the trick, "IF" I could fit them. That is where the 820 comes in. If it fits, it is a great alternative. Especially if you are a flap abuser. If not, there are a bunch of great slimmer choices. I still like the 94761 for everything in my gliders.
Also, check out the 809 servos for ailerons, and V-tails. They are really small and light. I haven’t used them yet, but Daryl likes them.
djklein21 is offline Find More Posts by djklein21
Old Dec 29, 2010, 03:53 PM
SmokinJoe101 is offline
Find More Posts by SmokinJoe101
SmokinJoe101's Avatar
Joined Jan 2004
3421 has it's place as Dave says "they are FANTASTIC servos" I like the speed and power of the 3421 and this is a contest PROVEN servo.. If you have the room 3421 all the way
sj
SmokinJoe101 is offline Find More Posts by SmokinJoe101
Old Dec 29, 2010, 04:05 PM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Flyin' Brian, its simple. The DS3421 is a JR servo, the 94820 isn't. Not much more to say. Remember, a few bucks saved on a $2000 airframe is chump change and increases risk. Go with the best.
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Dec 29, 2010, 04:16 PM
Swoopdown is offline
Find More Posts by Swoopdown
C'mon more Energy
Swoopdown's Avatar
Melbourne, Australia
Joined Mar 2005
I'm a big fan of the airtronics servo. Never used a Airtronics 94820 I assume they are the same as the 94761 with different gearing for more torque. I have only ever sprung for one 3401 (i think the model before the 3421) and its awesome on the full flying elevator of my big bird. But I'm still paying it off.
94761 proven on all surfaces to over 300mph in ds conditions give me some faith that just because they are half the price they are not half the quality.
I think tight slop free linkages and good geometry are more important than which servo you buy.
Swoopdown is offline Find More Posts by Swoopdown
Old Dec 29, 2010, 05:12 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
It's considerably thicker than a 761, though.
But now that more planes are using RDS, if it fits between the skin, it fits. No issue of the servo arm and flat covers when using RDS.
It might have to get tested on flaps if I ever build myself a bagged Supra, if it will fit.
If not, it would make one heck of an elevator servo I would think.
R,
Target
target is offline Find More Posts by target
Old Dec 29, 2010, 05:57 PM
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
3421
I have one coming in the mail JT. Thanks. I do really like the 761s over the 368s. I was just looking/asking around. Brian
JT
Old Dec 29, 2010, 06:01 PM
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
Thanks Dave for your comments..
Great flying BTW. Congrats. Brian
Also, check out the 809 servos for ailerons, and V-tails. They are really small and light. I havenít used them yet, but Daryl likes them.
Old Dec 29, 2010, 08:12 PM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
They are not in the same case as a 761. They are far thicker than the 761 but they have crazy power. Spencer, wold record holding DS pilot/designer/builder has been using then for the flaps in his recent DS ships. It should be noted that they are .050" thicker than the 3421.
Old Dec 30, 2010, 12:29 AM
jgs99v is offline
Find More Posts by jgs99v
Joined May 2006
Guys in some applications the 3421 is shorter in height than the 820 - I ended up using the 3421 just for this reason, and only this reason. Both are good servos. One thing I noticed is that no-one has mentioned that Airtronics ae manufactured in China, and most JR units are not. Don't know if that matters for product consistency and quality these days.
jgs99v is offline Find More Posts by jgs99v
Old Dec 30, 2010, 07:17 AM
C'mon more Energy
Swoopdown's Avatar
Joined Mar 2005
Thanks tor that. I'll be giving them a go in the next wing that think enough to try them in.
Old Dec 30, 2010, 11:40 AM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
The 94820 is slightly thicker than the 3421 as DK points out. Also, from the mounting lugs to the servo arm, height is the same. From mounting lug to bottom of servo, the 94820 is about 5mm taller.
Drive both near the limits of torque rating, the 94820 produces less heat.
The speed of the 94820 unloaded is about .188sec to turn 60degrees (6.6v) vs .135 for the 3421 (6.6v).
I don't think the 94820 is best for ele. That would have to be the JR DS3417 or the Z3650 (speed = .095, 6.6v), imo.
The gear slop out of the box in the typical 94820 is 1/2 that of the typical 3421. The 94820 is probably the better servo to use vs the 3421 for flaps if it fits. The speed of the servo is not as important here because the ail is most likely slower in deployment anyway due to geometry of linkages if set up optimally (ail servo travels 3x that of ail deflection).
fnnwizard is offline Find More Posts by fnnwizard
Old Dec 30, 2010, 11:48 AM
tewatson is offline
Find More Posts by tewatson
Tut, Tut...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
You mean DS3517, right? There is also now a HV version that is designed for unregulated LiXX packs - the DS3717.
Tom
tewatson is offline Find More Posts by tewatson
Old Dec 30, 2010, 11:54 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Tom
Correct Tom. 3517. too many servos to keep track of .
Old Dec 30, 2010, 02:50 PM
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
Not only are you one great guy, your also a bundle if information. ... Brian
Discussion Airtronics 94820 Servo Mark Miller Multi Task F3X 24 Aug 14, 2014 02:57 PM
Sold 3421 and 368 BrianSmith Aircraft - General - Radio Equipment (FS/W) 2 Dec 28, 2010 09:59 PM
Sold 3421 & 368 BrianSmith Aircraft - Sailplanes (FS/W) 0 Dec 28, 2010 10:16 AM
For Sale DX7 AR7000 3421's MN48 Gold delux switch flyinguy Aircraft - General - Radio Equipment (FS/W) 9 Nov 24, 2010 11:50 AM
Sold Mini Servos - JR 3421, 341, 321 - Futaba 3002 ChrisAttebery Aircraft - General - Radio Equipment (FS/W) 3 Sep 13, 2010 04:18 PM
