Old Sep 12, 2010, 11:14 PM
adbo is offline
Find More Posts by adbo
Joined Jul 2010
Base tracking patch antenna on top of the Quad!?
Why not?
You have these tracking antennas that allow you to increase the range by tracking your plane with a directional gain antenna.
Why wouldn't you be able to do this also on the Quad side, an Oktokopter for example should be able to hold the weight easily. Probably have to hang it under the kopter. To the electronics it doesn't make a difference whether it is the plane moving or the base station, does it? You could send video much further since that is the bottleneck..
Has anyone tried this?
adbo is offline Find More Posts by adbo
Old Sep 13, 2010, 05:36 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
The reciever antenna sensitivity is the most import part of a TX and RX system. You are better off with an Omni antenna on the TX of a moving platform and a higher DBI antenna on the tracking GS. IMO.
Directional antennas are big and you would need servos to operate them. Not to mention the added complexity of keeping a moving antenna pointed at a fix position. Stationary tracking systems have bugs, I can only imagine what issues you would have with a 8dbi patch on an Octo.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Sep 13, 2010, 08:40 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ
Joined May 2010
why not just use the same setup on a quad and let the base antenna move to track the quad?
bob4432 is offline Find More Posts by bob4432
Old Sep 13, 2010, 09:02 AM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
There is no reason to put a patch antenna on the vehicle. It's easier to point the patch in the general direction of the vehicle than it is to constantly point the moving/rotating vehicle at the base station.
vic20owner is offline Find More Posts by vic20owner
Old Sep 13, 2010, 09:35 AM
adbo is offline
Joined Jul 2010
You would then have a patch antenna for the video on both sides of course. If you win a lot by using it at the base then you win just as much again by doing it on the sending side, right?
A base tracking patch antenna should be able to keep up with a decent behaving quad I would think?
(Absolute beginner here obviously, just got my brand new Oktokopter to fly for 11 minutes with an extra kilo on top of a 5000mAh lipo, 20 minutes normally. And then I let it cut me..ffffk. Sanding the sharp residue plastic from the props is a good idea, just in case..)
Old Sep 13, 2010, 12:24 PM
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
I would recommend going to the FPV forum, and reading up on antenna gain patterns.
A 500mW transmitter, a patch antenna on the receiver, and a simple 3dbi gain antenna on the aircraft will give you far more range than your rc transmitter will operate.
Also, you will need a HAM radio license if you are in the USA.
Old Sep 13, 2010, 04:27 PM
bob4432 is offline
bob4432's Avatar
United States, AZ
Joined May 2010
have a look at this thread for some serious range for a quad - http://www.rcgroups.com/forums/showthread.php?t=1147430
Old Sep 13, 2010, 05:01 PM
Tarro is offline
Joined Jun 2008
Your getting 20 minute flights from a single 5000mah battery? What does your Octo weigh?
Old Sep 13, 2010, 05:04 PM
adbo is offline
Joined Jul 2010
I saw the long range threads and I am not really interested in doing that. Just wanted to know if there is any reason why it couldn't work?
You could in theory do that for both the Video Tx and the Radio Rx. I just thought a quad is a different platform that can do thing normal planes can't. How much range difference could it make?
Then of course battery would become the bottleneck, you never come back.. but let's ignore that..
Old Sep 13, 2010, 06:15 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
You would need a compass for heading
Gps can tell ur heading if ur moving forward but if u stop the quad won't know where home is and it wouldn't aim the patch right
Since patch antennas have high gain, if the antenna points the wrong way u will lose video
I thought about putting a patch on the bottom and aiming it straight down for a high altitude platform but I would need 2 circular patch antennas
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Sep 14, 2010, 06:46 AM
adbo is offline
Joined Jul 2010
The mikrokopter has a pretty exact compass,
You'd want enough spread of the signal for some banking, but then again with the telemetry view in Google earth and Hight hold you'd be pretty sure where you are anyway, a few second loss isn't that bad is it?
Old Sep 14, 2010, 06:56 AM
adbo is offline
Joined Jul 2010
Guess the mikrokopter itself could be the tracker, always setting its backside in the direction of the base.
You'd need a flexible fpv cam so you can keep looking in the direction of flight..
Old Sep 14, 2010, 01:33 PM
tori3 is offline
Find More Posts by tori3
Joined Jun 2009
You'll want to have an aux omni antenna on the a/c anyway, in case the patch servo goes down. That spells heavy.
Pros: a few measly dBs of gain that you're not gonna use anyway since you have to stay LOS.
Cons: cost, low reliability, extra time you put in it, weight, power consumption.
Is it worth it?
tori3 is offline Find More Posts by tori3
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 350 Feb 27, 2015 02:12 AM
Discussion Base station tracking ziomatrixacs FPV Talk 6 Aug 25, 2010 06:38 PM
Sold Berg 7P top load receiver with base loaded antenna Greg Gimlick Aircraft - General - Radio Equipment (FS/W) 0 Feb 14, 2010 11:42 AM
Discussion 8dbi 900mhz patch antenna on ebay fpvdavid FPV Talk 2 Nov 07, 2009 07:09 PM
Discussion Patch antenna put on car top tungym FPV Talk 2 May 21, 2009 11:01 AM
