Old Dec 13, 2002, 10:29 AM
Virginia
Joined Dec 2002
Foam Building Boards
Does anyone know of a source for foam building boards?
I'm looking for one about 40"X36" and about 3/4" thick.
TIA,
Matt
3Wheels is offline Find More Posts by 3Wheels
Old Dec 13, 2002, 04:46 PM
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Are you sure you need a foam building board?
I've always used a 2" X 4" ceiling tile turned over and found them to work just fine. Ask your local building supply place if the have any with broken corners and it shouldn't cost more than a $1.
jimsp is offline Find More Posts by jimsp
Old Dec 14, 2002, 04:46 AM
Will work for planes
omega blood's Avatar
Fullerton, California, United States
Joined Jan 2002
Try you local art supply store or wallmart. The art store will have the bigger sizes.
omega blood is offline Find More Posts by omega blood
Old Dec 14, 2002, 07:49 AM
W. Bloomfield, Mi
Joined Oct 2002
How do you keep the board from developing "warping"? Are you mounting the tile onto another surface ie a sheet of plywood? Thanks
Michael
msp1957 is offline Find More Posts by msp1957
Old Dec 14, 2002, 09:30 AM
Fowlerville,MI
Joined May 2002
building board
Go to one of the " big box" stores. The building supply dept. will have different tyes of foam boards or perhaps some other suitable material in 4` x 8` sheets . Cut it to whatever size you need. You will need a flat table to lay it on tho.
traskos is offline Find More Posts by traskos
Old Dec 14, 2002, 09:31 AM
tekochip's Avatar
West Dundee, IL, USA
Joined Jul 2001
Yea, glue the tile to pressed wood or something cheap like that. Most home centers even have "handy boards" that are the right size.
tekochip is offline Find More Posts by tekochip
