This thread is privately moderated by Spadplanter, who may elect to delete unwanted replies.
Old Mar 01, 2014, 09:34 PM
just about Anything can fly
AERIAL MADMAN's Avatar
Australia, NSW, Coffs Harbour
Joined Aug 2012
Hey folks thought i would share some of my corflute-correx-corro-plastic board-stuff builds.
AM
AERIAL MADMAN is offline Find More Posts by AERIAL MADMAN
Old Mar 03, 2014, 10:16 AM
Canada, ON, Cottam
Joined Jan 2012
The checkerboard pattern really stands out nicely.
aspeed is offline Find More Posts by aspeed
Old Mar 11, 2014, 02:26 PM
Spaderman's Avatar
France, PCh, Puy-du-Lac
Joined Mar 2010
Hello all,
My youngest !
- span : 660mm
- weight : 630grs
- motor : 1400kv
- accus : 3s 1500mAh
Transfer test Depron / Coro with a single sheet for the wing !
I think replacing the electric motor with a .15 nitro ...This should be interesting!
Soon a vidéo
Spad
Spaderman is offline Find More Posts by Spaderman
Old Mar 18, 2014, 08:50 AM
3dholic
Croatia, County of Zagreb, Ivanić-Grad
Joined Apr 2007
hy guys
this is my mig 7 with leo 46 on it. goes like hell
video
https://www.youtube.com/watch?featur...ODCO4uLxQ#t=51
under construction 1400 mm ju 87 stuka
eewan is offline Find More Posts by eewan
Old Mar 21, 2014, 10:17 PM
GLHS592's Avatar
United States, TN, Nunnelly
Joined Aug 2012
Originally Posted by Spaderman View Post
Hello all,
My youngest !
- span : 660mm
- weight : 630grs
- motor : 1400kv
Soon a vidéo
Spad
That is a really cool plane. Can you point me to a set of plans for it?
GLHS592 is offline Find More Posts by GLHS592
Old Mar 24, 2014, 02:39 AM
Spaderman's Avatar
Joined Mar 2010
Hello GLHS592
FREE Build Plans: http://flitetest.com/articles/ft-22-raptor-build
A little vidéo
F22 Cororaptor (3 min 5 sec)
Spad
Old Mar 24, 2014, 12:21 PM
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined May 2008
Nice flier!
rockyabq is online now Find More Posts by rockyabq
Old Mar 24, 2014, 03:24 PM
TrevorJS's Avatar
South Africa, EC, Port Elizabeth
Joined Oct 2012
Originally Posted by Extreme Sports View Post
Been meaning to build this for some time. Was thinking of using depron, but the SE5A shape just calls out to be made from correx, so the correx won in the end. Construction is all 2mm correx with 3mm foamboard formers. Wings are a simple curved plate and ply is only used for the wing ribs, struts and firewall. Cockpit coaming is the plastic insulation from electrical wire. Radiator and engine are painted foam. No cable ties used, but I did use duct tape for the dihedral joints, so you can call this a true SPAD!
AUW is a shade over 700g (the wheels and scale details just keep on adding weight!). Power is a hobbyking 2826 1400KV motor and 1300mAh Lipo.
Hi ES
I love your SE5A! What is a the wingspan and how does it fly? Do you have any build pics? Trevor
TrevorJS is offline Find More Posts by TrevorJS
Old Mar 24, 2014, 04:54 PM
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
Originally Posted by TrevorJS View Post
Hi ES
Span is 800mm IIRC. Unfortunately I did not take any build pictures, except for the 'jig' I used to get the wings properly aligned.
I've obviously never seen an SE5A fly, but this flies like I would expect a vintage plane to fly - stable and slow. I used a very old set of plans for a rubber powered model (scaled up to 800mm) and I think there is too much incidence as it needed an unsightly amount of down thrust and slight down elevator trim. If you watch the video (link below) you will see a regular porpoising that I also attribute to this....but its too much effort to try to change the incidence now.
Also, the ailerons had absolutely zero effect and I needed to double the rudder size for it to give me the sensitivity I wanted....probably both effects linked to the curved plate airfoil and inherently stable design....much like the original from what I hear.
I really enjoy flying it just as the sun sets on a winter evening when there is absolutely no wind...at least 1 spectator has commented on how real it looks. Landings are the best....it has so much lift and drag that it just slowly floats in with the throttle at about 20%.
And just like the original it needs regular minor maintenance especially to the rigging wires and to touch up the paintwork!
There is a video on this page: http://www.rcgroups.com/forums/showp...7&postcount=54
EDIT: Oops, I see from this link that the span is 900mm
EDIT 2: Plans scaled up to 900mm attached
Extreme Sports is offline Find More Posts by Extreme Sports
Old Mar 24, 2014, 05:09 PM
GLHS592's Avatar
Joined Aug 2012
Thanks! Nice video!
Old Mar 26, 2014, 12:02 PM
TrevorJS's Avatar
Joined Oct 2012
Thanks for the SE5A plans ES. This is definitely on my to-do list!
Trevor
Old Mar 26, 2014, 12:12 PM
TrevorJS's Avatar
Joined Oct 2012
Piper Cub
Here's my 1.4m WS Piper Cub I built from Correx. Flies nice and steady with a Park480 motor and has plenty of lift from the Clarke-Y airfoil wigs (wire-cut foam core skinned with Correx). ps. my daughter chose the colour scheme...
Old Apr 20, 2014, 02:04 AM
Happiness is a warm ESC.
Stretch1's Avatar
Ballarat Vic. Australia
Joined Jun 2008
New SPAD ready for maiden...
Details in my blog:
http://www.rcgroups.com/forums/showt...2#post28139235
Stretch1 is offline Find More Posts by Stretch1
Old Apr 27, 2014, 04:45 AM
Stretch1's Avatar
Joined Jun 2008
Nitro or LiPo it's all go!
Sunday flying at the club.
Old Apr 27, 2014, 07:39 AM
Joined Nov 2012
can you post some detail of how you made the delta wing?
goly is offline Find More Posts by goly
Gallery Let's see your boats flailing Scale Boats 257 Mar 08, 2012 02:38 PM
Idea Let's see your sloper pics! Ben74 Slope 161 Aug 04, 2005 06:44 PM
Let's see your pilots! DennisG Electric Plane Talk 39 Jun 09, 2003 07:05 AM
Let's see your Pumkins! Troy Life, The Universe, and Politics 27 Nov 08, 2002 12:00 AM
Hey Doug! Let's see a T-6 Texan!!! CheeseWing Parkflyers 9 Oct 13, 2002 02:51 PM
