Old Mar 08, 2014, 10:33 PM
Joined Mar 2014
tips/tricks on a nice rounded LE
This is my first kit build and im rounding the LE on my tail wing. Does anyone have any good tips or tricks on getting a nice uniform round edge. I seem to be getting it good in one spot and then another wont like so good so i go back to it then have to go back over the other spots. Thanks for taking to time to read and give some feedback. By the way the kit is the top flight p51 gold edition.
Jarod
NY0331 is offline Find More Posts by NY0331
Old Mar 09, 2014, 12:35 AM
Australia, VIC, Ferntree Gully
Joined Nov 2010
Wood plane.
Then lightly sand.
peterreebok is online now Find More Posts by peterreebok
Old Mar 09, 2014, 04:51 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
+1 for the use of the plane (The David plane is very good), then make up a looong sanding block for the finishing off.
Trevorh is offline Find More Posts by Trevorh
Old Mar 09, 2014, 09:44 AM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Plane, Black and Decker sanding mouse. Cup of coffee. Take your time.
Our mouse is on a dimmer thing and has variable speed. If you are in a hurry,
do something else.
Kimber is offline Find More Posts by Kimber
Old Mar 09, 2014, 12:47 PM
aymodeler's Avatar
United States, CT, Hartland
Joined Jul 2011
+ 1 on both the long block and the plane. The long block is key to getting the LE even. Work on the entire length, not just one section. To rough shape, I like to use a somewhat "diagonal" motion (relative to the LE), where I start on the upper surface on one end and continuously rotate around to the lower surface by the time I reach the other end of the wing. I do one direction for a few passes, then reverse and start working the other way. Once I get close to the final shape, I will revert to motion that is straight along the length of the LE to eliminate any diagonal sanding marks.
Also, when sanding keep repeating to yourself "less is more" This is a lesson I keep needing to teach myself over and over, but if you are not getting the results you are looking for quickly, resist the temptation to press harder, sand faster, or sand more. Instead, either change out your paper (because its worn), or just be patient and work slowly.
aymodeler is offline Find More Posts by aymodeler
Old Mar 09, 2014, 06:46 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I like to draw a line that splits the surface in two halves. Now I only have to sand on side at a time only to the line. do the other side and then a light touch up on the drawn line to even it out. +1 on the long sanding block.
Ken
kenh3497 is online now Find More Posts by kenh3497
Old Mar 09, 2014, 07:11 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
If the LE is straight take a full sheet of sand paper, bend it over the LE and pull back and forth on the ends. Slide it along the wing as you go. Long edge in line with the span
The closer you hold it down to the wing the smoother the transition will be from the LE to the sheeting.
pmackenzie is offline Find More Posts by pmackenzie
Old Mar 09, 2014, 07:23 PM
Since 1952
Harry D's Avatar
Canada, AB, Edmonton
Lots of good advice above.
Also, make and use a template so you get the correct LE shape - which is not necessarily just "rounded". This is particularly important with larger sections.
As most things do, it gets easier with practice.
Harry D is offline Find More Posts by Harry D
Old Mar 09, 2014, 08:49 PM
FICKLE FLYER
tlh101's Avatar
Corpus Christi, Texas, United States
Joined Dec 2002
Since I just happen to have a leading edge that needs shaping on my 1/4 scale Tri Pacer build, I thought I would document my process here.
tlh101 is online now Find More Posts by tlh101
Old Mar 10, 2014, 04:27 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Excellent picture guide - and a nice wing too!
Old Mar 10, 2014, 07:50 AM
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
That's my method, too.
I use a plane, first, to get the leading edge roughly to size and shape.
The method is quick and easy.
Basically, it's what Terry has photo documented for us.
TomCrump is online now Find More Posts by TomCrump
Old Mar 10, 2014, 08:07 PM
pmackenzie's Avatar
Joined Dec 2002
His "shoe-shine" analogy described it perfectly, much better than I did.
Old Mar 15, 2014, 09:42 AM
builderdude's Avatar
United States, TX
Joined Jun 2011
I've always "eyeballed" it, but I admit, I like this method. I need to find one of those balsa planes (woodworking plane, not airplane).
builderdude is online now Find More Posts by builderdude
Discussion Cold Weather Flying Tips, Tricks and Gear transient Scratchbuilt Multirotors 41 Nov 20, 2014 04:03 PM
Discussion GoPro2 tips n' tricks TheNiceGuy Aerial Photography 4 Dec 09, 2013 02:16 PM
Discussion V944 Threads,Tips & Tricks nip619 Micro Helis 1 Sep 26, 2013 05:36 AM
Mini-HowTo Tom's Tips and Tricks (LE treatment) TomFlyer Slope 31 Aug 21, 2009 12:13 PM
