Old May 06, 2013, 06:52 PM
AZ Model Aviators, EVA
bpking's Avatar
United States, AZ, Gold Canyon
Joined Jun 2010
Need prop info for monster 110 motor
Hi guys, I have a nitro planes Cessna 84" wing, 12 lb. airplane. I have installed a monster 110 motor, 80amp HV esc, running on 2- 4 cell 4000 batteries. I would like to run a 3 blade prop on this acft. What size would be best? Thanks
bpking is offline Find More Posts by bpking
Old May 06, 2013, 08:03 PM
In charge of laundry & morale
Eplane's Avatar
United States, NY, Spencerport
Joined Sep 2003
I'm digging as well. The closest info I've found is an old Ebay listing that said they bench ran it on 8s with an 80a esc with a 17x10 2-blade prop.
That's where I'm going to start and use watt-meter readings to "tweak in" what prop I'll use.
http://www.ebay.com/itm/EXCEED-RC-MO...-/330575781724
Eplane is offline Find More Posts by Eplane
Old May 06, 2013, 08:08 PM
Eplane's Avatar
Joined Sep 2003
These seem like good "E" 3-blades, might be a start.
http://sdshobbyusa.net/index.php?mai...oducts_id=2597
Old May 06, 2013, 10:45 PM
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
If it's any help I run the Eflite 110 in my TF Corsair, 9S with a 14x10x 3
I ran the specs dropping to 8S, and came up with 51 amps, 12.5 pounds of thrust and an air speed of 70 mph.
Glacier Girl is offline Find More Posts by Glacier Girl
Old May 07, 2013, 12:26 AM
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
The Monster Power 110 is a clone of the E-Flite Power 110, which is nice because you can spec out your setup by using any number of online power system calculators. My personal fave is eCalc, which I use via Castle Creations:
http://www.castlecreations.com/suppo...alculator.html
You can choose the E-Flite Power 110 motor, a HV80 ESC, an 8s 4000mAh batt with whatever C-rating you have, your altitude, temperature, the level of cooling in your plane, and then play around with different propeller sizes until you get the thrust/power/current draw numbers that make you happy.
Hope that helps,
Josh
jgalexander is offline Find More Posts by jgalexander
Old May 07, 2013, 09:09 AM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Just a note on the EMP 16/8/ 3 bladed props suggested. They are excellent propellers, giving excellent value for the $$, with good flight characteristics and sturdy. Lighter than the MAS equivenlants, but just as robust imho.
I'm using the EMP line of 3 bladers on 5 aircraft at the moment. Every one of them where balanced perfectly out of the bag, I checked because I fought with MAS props (every one!!) to get them balanced at all.
In my testing of a 16/10/3 MAS, I felt the 16/8/3 EMP produced more thrust at slightly less amps. fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old May 08, 2013, 01:37 PM
bpking's Avatar
Joined Jun 2010
thank you all for the help.
Question need help with battery motor props for turnigy plush 30A ESC useit4me Scratchbuilt Multirotors 5 Apr 22, 2013 07:54 AM
Help! I need Hobby Lobby Telemaster 70 motor/electronics info potshot Power Systems 6 Apr 07, 2013 05:28 PM
Help! Monster Power 46 battery and prop help needed the_law_man01 Power Systems 9 Mar 21, 2013 05:40 PM
Discussion Monster 110-need prop/spinner adapter? Ldm Electric Motor Design and Construction 12 Jan 28, 2012 05:24 AM
Discussion what 3 blade prop for a monster 110? Ldm Power Systems 25 Dec 21, 2011 05:58 PM
