Old Feb 10, 2013, 08:24 PM
Joined Apr 2012
My 2nd Slickest Trick In CL-Someone Must Have Done This Before But I'd Never Seen It
before I "invented" it. Hinge the rudder and install a control horn with a clevis anchored to the vertical fin. We've all seen someone crash a brand new plane as it came in on the lines. Use lots of rudder, than find that sweet spot and glue or fix the rudder and remove horn, clevis, etc.
tigreflyer is offline Find More Posts by tigreflyer
Old Feb 10, 2013, 10:13 PM
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
Hate to say it but you haven't actually invented it . There's another version called a Rabe Rudder where the rudder is linked to the elevator. Up elevator gives a small reduction in rudder deflection while down increases it. The idea of this is to use the rudder to counteract yawing of the nose due to gyroscopic precession of the prop.
downunder is offline Find More Posts by downunder
Old Feb 10, 2013, 10:26 PM
i made an adjustable rudder by putting a slotted plywood plate on the bottom end of the rudder. An allen head bolt through the slot into the fuselage kept it in place. I learned quite a bit by fiddling with it. Now, I build rudders with 0 offset, except for OTS airplanes where a little is needed to make it look right.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Feb 10, 2013, 11:16 PM
flyelectcl's Avatar
Joined Oct 2008
years ago (prior to 1975) carrier planes often used a movable rudder when the plane went into slow speed. The rudder was connected to the same mechanism that operated the ailerons, usually the hook release. after sliders came into the picture it wasn't needed. Today it is only seen on nostalgia models.
Another trick was to use a spring on the rudder, during high speed it would straighten, when you slowed down you would get more rudder offset.
I still have planes with both systems
flyelectcl is online now Find More Posts by flyelectcl
Old Feb 10, 2013, 11:59 PM
flyelectcl's Avatar
Joined Oct 2008
PS attached is a drawing of the carrier rudder system
Old Feb 11, 2013, 08:22 PM
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
More than one of us has done something similar.
I didn't actually hinge a section as large as a full-scale propeller driven plane might have, more like a large trim tab. I was already pretty sure that rudder offset was counter-productive. But all the circumstances have grown vague with time. It had to have been the early 1970s, perhaps before that. I have to guess that it related to a sport plane, either a Buster or a Shoestring.
Maybe Jeff would remember, but he would've been very young (under ten, probably).
Kiwi
The Kiwi is offline Find More Posts by The Kiwi
Discussion My Slickest Trick In CL tigreflyer Control Line 1 Feb 10, 2013 04:30 PM
Discussion My 3 Slickest Tricks In CL tigreflyer Control Line 6 Oct 27, 2012 10:26 AM
Discussion Never seen before Video Footages done on the NE Solo Pro EQMOD Micro Helis 10 Aug 19, 2010 08:23 PM
Discussion You have never seen anything like this before. austinelse Batteries and Chargers 231 Aug 03, 2010 03:24 PM
Lipo question, I have never seen this before MailOrderGuy Batteries and Chargers 10 Jun 29, 2004 09:19 PM
