Old Apr 08, 2012, 04:38 AM
France
Joined Sep 2011
@Timecop: Good idea! The skyartec RX lacks of ppm output, so it would be cool to use the frsky instead!
@Bracame: I really have problems to understand how the channel sync is made between the TX and RX (after you have pushed the bind button on the RX).
I may have missed something with connections between the STM8S and the cc2500, because I guess GD02 should be connected somewhere.
Would it be possible to checks the pins on your side?
cc2500 board connections, from left to right
1 R28 -> PA4 (not really connected, missing resistor?)
2 R29 -> not connected ?
3 R30 -> PA5 (CSn)
4 R31 -> PA6 (GDO0 / ATEST)
5 GND
6 R32 -> not connected ?
7 R33 -> PC7 (SPI_MISO)
8 R34 -> PC5 (SPI_SCK)
9 R 35 -> PC6 (SPI_MOSI)
10 C24 -> VCC
sbaron is offline Find More Posts by sbaron
Old Apr 09, 2012, 03:46 AM
France
Joined Sep 2011
I surrender: I've spent too much time trying to understand how the rx bind works, and I've obviously broke something, because now my tx/rx doesn't even bind with the original skyartec firmware... When I'll some time, I'll probably desolder the cc2500 module to replace it with a corona diy kit...
Old Apr 09, 2012, 12:39 PM
Apprenti
Bracame's Avatar
France, Basse-Normandie, Négreville
Joined Oct 2011
Sorry for the delay and for your cc2500 if it is dead (try to reset all possible think , another code here http://www.rhydolabz.com/documents/w...ample_code.zip)
For the connection, you'r wright. Some better photos :
Bracame is offline Find More Posts by Bracame
Old Apr 09, 2012, 12:55 PM
Apprenti
Bracame's Avatar
Joined Oct 2011
... And does your sky705 seem to work ok with skyartec software via usb ?
Old Apr 10, 2012, 03:30 AM
France
Joined Sep 2011
According to me the stm8 mcu is a good choice, but the conception of the sky705 is really bad. For example, they don't use the SPI or UART peripherals and bitbang everything! Why a ch372 instead of something like cp2102? The uart2 pins are wired to .... an unused pad.
So I didn't even bother trying to "resurrect" the cc2500. I removed it - and the ch372 - and now I've a lot of free IO
I'll probably implement a ppm encoder and add a 2.4ghz rf module (frsky, corono or a fs-hf030).
I'm sorry not being able to help you. Using the cc2500 itself is easy, the main issue you'll have is to understand the proprietary method used to bind the rx with the tx. It doesn't seem to be documented in the specs or in any lib I've seen.
Old Apr 10, 2012, 08:07 AM
Joined Dec 2010
ch372 = Cheap chinese USB chip. Probably 1/10th the price of CP2102
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Apr 10, 2012, 01:02 PM
Apprenti
Bracame's Avatar
Joined Oct 2011
Without a specialiste like Sbaron, this post is dead. I've learn c library of stm8 , watching the asm code, trying playing with ida in st7 mode , etc .....
As we says in France : I'm swimming into a big smog !! (not andertand all)
Since I've my discovery, the second solution is possible. Xavier give me he's code and I'm trying to modify it as my mind ....
Skyartec win this battle but I espect not the war !
Thanks a lot to you
Old Apr 10, 2012, 01:23 PM
France
Joined Sep 2011
It's not totally lost. I can't help for cc2500 support but even without this, the TX itself has a good potential.
Replace the rf module by something like this: http://www.hobbyking.com/hobbyking/s...Y_Module_.html
and you'll have a very cool tx.
If you're interested, I still can provide some code for inputs, ppm output, led and uart
Old Apr 10, 2012, 01:34 PM
Apprenti
Bracame's Avatar
Joined Oct 2011
Thanks !
Of course i'm interested and i think a lot of people ho have this anti freedom tx !
If anyone is intersted, say in your opinion !! Skyartec : the best tx at +60 S !!!!!
(prefer turnigy !!! for the price)
Old Apr 12, 2012, 07:10 AM
Apprenti
Bracame's Avatar
Joined Oct 2011
Here is Xavier's source (provide without any warranty )
I'll modify it for 6 channels and setting parametres with a 16X2 lcd.
If possible, fms ppm with uart on a rs232 output.
http://sites.google.com/site/stm8sdi...-2-4ghz-module
Old Apr 12, 2012, 12:28 PM
France
Joined Sep 2011
Here are some sources that could help coding something for this remote.
There is still a lot to do before having something usable...
As my remote control is seriously altered, I can't help more.
Old Apr 14, 2012, 07:24 PM
Apprenti
Bracame's Avatar
Joined Oct 2011
Thank you Sbaron, I've a question ....
If i boot the cc2500 with the original board (configuration ...) and after switch to mine, does the cc will accept ?
I'm working on my discovery board, Xavier'sources are a lot modified.
And i'm waiting for that : http://cgi.ebay.fr/ws/eBayISAPI.dll?...84.m1497.l2649
For easy setting of the tx.
Last question : a buddycode for corona diy ??? ;-)
Old Apr 16, 2012, 09:44 AM
France
Joined Sep 2011
The previously attached code already configure the cc2500 exactly as the original firmware. What's missing is the code to find the address and the channel used by the receiver, and then store it into the structure rx_config. Without reversing the original firmware with a debugger or a disassembler, I doubt that you can transmit something.
Regarding the corona, it would be easy to add support since it needs only ppm input. See: http://www.mftech.de/ppm_en.htm
You have to configure a timer to generate an interruption every 22.5ms , something like that :
Code:
TIM3_DeInit();
// ( 1 / ( 16Mhz / 64 ) ) * ( 5624 + 1 ) = 22500us
TIM3_TimeBaseInit(TIM3_PRESCALER_64, 5624);
TIM3_ITConfig(TIM3_IT_UPDATE, ENABLE);
TIM3_Cmd(ENABLE);
And then in the interrupt handler, generate the signal using GPIO_WriteLow / GPIO_WriteHigh / delay_us. The PA4 pin, wired but not used, would be usable for this.
I've just managed to get a th9x rc, so I'm not very motivated to continue with this for now...
Old Jun 11, 2012, 07:49 PM
Apprenti
Bracame's Avatar
Joined Oct 2011
Finishing
Hi,
C learned :
I'm finishing my new TX with the discorery board. (whith a 16X2 LCD and corona diy module)
- 6 input proportional (2 stick and 2 pots)
-2 input with 3 positions switch
-1 switch for engine stop
-1 switch for dual rate
-1 switch for changing phase
-1 switch for ?? (i wonder what to do with)
-1 little push button for dynamic trim (setting actual position to neutral position)
-1 jack ppm output for usb simulator
- 1 little switch for unpowering the corona when i simulate
-4 microswitch for sttings
- 8 ouput (corona)
software settings (with lcd):
pots calibration
DR (percent)
expo (negative & positive gain -99 to 99)
16 mixer input-ouput-gain+&gain- (will increase to 20 if needed)
Min,neutral,max for output
power of motor for timer in proportional mode
beep/nobeep
etc ..
memory (in flash) : 4 model with 2 phases
Stm8 is powerfull !! but have little flash ..
Will send pictures when availables ...
Thank you again for your help
Old Aug 07, 2012, 07:34 PM
Apprenti
Bracame's Avatar
Joined Oct 2011
The post !! (in french)
http://www.modelisme.com/forum/aero-...ce-maison.html
Question Skyartec 705 Buddy / Trainer setup ZippoZ Skyartec 13 Mar 29, 2012 08:01 PM
Question Skyartec 705 - Dual Servo Ailerons? ZippoZ Skyartec 10 Mar 28, 2012 12:07 PM
Help! Skyartec sky-705 receiver West Oz Mark Power Systems 0 Feb 28, 2012 12:20 AM
Alert Sky705 Simulator Issues Parkflying Skyartec 25 Mar 20, 2011 09:23 AM
Help! SKY705 issues jkaxford Skyartec 15 Feb 02, 2011 03:04 AM
