Old Jan 26, 2012, 12:21 PM
Joined Jan 2012
Question
what propeller to use
I have an older Dumas 30" Pay n Pak with an OS max.21 RGMX. Right now I use an Octura X442 prop. It runs pretty good but just wondering if anybody could recommend a better choice. Acceleration isn't as good as I'd like. Any ideas?
mark 5388 is offline Find More Posts by mark 5388
Old Jan 28, 2012, 12:14 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
You might need to prop down a little if it's slow getting up to speed. Generally, most .21's like props in the 37-40mm range. You're working with a comparatively heavy boat so it's a lot to push. A smaller prop will enable it to not only get up to speed faster but also may make it faster as it will alow the OS to rev higher.
Ron Olson is offline Find More Posts by Ron Olson
Old Feb 08, 2012, 10:37 PM
XRated's Avatar
Joined Jul 2011
I'd try a 1440 Octura prop on that hull design with a little cupping at the inner trailing tip about 1/4" long at the first radius ramp...........
XRated is offline Find More Posts by XRated
Discussion What size lenses do you use for what style of flying?? dallibab FPV Talk 15 Oct 27, 2011 01:11 PM
Discussion What's the most lights you have put on your HZ Champ and what did you use newflyer100 Micro Ready-to-Fly 0 Jul 12, 2011 11:27 PM
Help! what propeller is better dnchvs Dock Talk 4 Apr 02, 2011 11:55 PM
Rant What kind of controller do you use? What should I use? Solaris1985 Electric Plane Talk 10 May 27, 2009 03:25 AM
Discussion Which Propeller To Use norgale Scale Boats 4 Dec 22, 2007 08:51 AM
