Old Sep 13, 2011, 10:17 PM
spencer6891's Avatar
NC
Joined Aug 2004
Help!
FMS P-51 w/ Turnigy 5055 - spinner problem
Hi,
I have upgraded my FMS giant P-51 with a Turnigy 5055 580 motor but I am trying to figure out how to adapt the spinner backplate to the shaft. The shaft is 8mm and the backplate hole is 5mm. I drilled out the hole (a little larger than 8mm) but cannot get the thing to spin true without wobble. Any idea how I can do this, or should I look for a different spinner?
spencer6891 is offline Find More Posts by spencer6891
Old Sep 14, 2011, 01:21 AM
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
Originally Posted by spencer6891 View Post
Hi,
If it's wobbling chances are you got the hole off center when you drilled it.
Herman Munster is offline Find More Posts by Herman Munster
Old Sep 14, 2011, 02:15 AM
USA, CA, Huntington Beach
Joined Jun 2005
Spencer.
You can contact Terry at www.smallpartscnc.com. I had him make me a run of prop adapters for the FMS birds with both Turnigy 42-xx and 50-xx bases and FMS style shafts that fit the P-51 spinner. He hasn't listed them on his site yet, when you contact him just tell you want the ones like he made for Gary.
gbancrof is offline Find More Posts by gbancrof
Old Sep 14, 2011, 02:57 AM
NC
Joined Aug 2004
Wow, thanks a lot gbancrof. Will do. Did he make the shafts to fit both the new and the older version spinners? I just discovered that the new (V6) spinner has an 8mm hole, which I thought would be a slip on fit for my 8mm shaft, but apparently it still needs reaming to fit properly.
Old Sep 14, 2011, 08:53 PM
Joined Jun 2005
Spencer,
I just had him do the new V6 spinner, which also has the same hex base that the new FMS hubs have like the one for the P-47 four bladed prop. Terry is very accommodating and can tweak the shafts to your needs. I had him add a 1/2" to my shafts just in case I needed it.
New Product FMS North American P-51 D Mustang 1700mm (67 inches!!!) Beltpilot Electric Warbirds 9660 Dec 17, 2014 10:03 PM
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Electric - Airplanes (FS/W) 11 Sep 14, 2011 03:55 PM
Sold NEW FMS 57" P-51 Mustang with upgrades godofthunder77 Aircraft - Fuel - Airplanes (FS/W) 2 Sep 04, 2011 02:41 PM
Sold FMS/Airfield P-51 Mustang V6 - Newest Version w/ tail retract, nav lights, more: BNF Roswalt Aircraft - Electric - Airplanes (FS/W) 9 May 25, 2011 12:08 PM
For Sale Tru-turn P-51 spinner w/adapter $15 crashnburned Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 30, 2007 02:34 PM
