Old Jan 23, 2008, 05:47 PM
Joined Dec 2006
Data
Wing Dragon/ Areobird Swift
We just placed our order for a Wingdragon from Hobby Lobby.. We have an Aerobird Swift. The swift seems a bit fast for my grandson. WHAT SHOULD I KNOW BEFORE WE FLY THE WINGDRAGON????? I found the swift flew better after I added some nose wieght. Glide was better, landings picture perfect. Any advice on either of these planes will be appreciated. I have some 7 cell batteries for the Aerobird Swift. They are 7 cells each. WILL they work (if we change connectors with the Wingdragon? The Swift as a 480 motor runs on 8.4 volts.. Will that voltage work with the Wingdragon? Thanks, Chief.
Chief Redelk is offline Find More Posts by Chief Redelk
Old Jan 23, 2008, 06:04 PM
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
I believe the wingdragon uses 7 cell batteries also so your batteries should work.
GoldCraft is offline Find More Posts by GoldCraft
Old Jan 23, 2008, 11:05 PM
Joined Sep 2006
I believe your wing dragon will fly much better with a 9.6V, 8 cell pack... but the 7 cells should run it okay.
rwhite0604 is offline Find More Posts by rwhite0604
Old Jan 23, 2008, 11:50 PM
Watch out for that TREE!
Houston, Tx
Joined Oct 2006
The wing dragon comes with the 7 cell, 8.4 v batt. pack. You should be OK. The WD's stock motor is "approx. a speed 400 size" so it's a bit smaller/less powerful the the 480 in the AS, so that should be good for your grandson. It's generally, well regarded as a trainer, so again, should be good for your grandson the learn on. I'm assuming you ordered the 3 channel version.
Good luck and good flying,
John
GD5015 is offline Find More Posts by GD5015
Old Jan 24, 2008, 12:15 AM
Joined Dec 2006
I thought I was getting a real 4 channel radio with the Wing Dragon. BUT now I see it's like the Cheap HOBBY ZONE transmitter. YET I am told it's 72 MHZ. I wonder is the reciever a real one that can be taken out and placed in another plane?
Old Jan 24, 2008, 12:17 AM
Joined Dec 2006
Has anyone flow BOTH the Wing Dragon AND the Hobby Zone Swift? if so how do they compare? I read that the Wing Dragon needs an air hole drilled in the nose so that it will cool? Has anyone had over heating problems with the Wing Dragon?
Old Jan 24, 2008, 11:20 AM
GoldCraft's Avatar
Joined Jan 2007
The Wing Dragon 4 has a real 4 ch 72mh system.....Wing Dragon 3 channel does not. The 4 also has a bigger motor and uses 8 cell batteries.
You can buy the Wing Dragon 4 and buy a 3 ch wing for it .....train with that then move on to the aileron wing and use it for an aileron trainer. this way you get the 72mh system and 2 types of trainers.
Old Jan 24, 2008, 12:33 PM
Joined Dec 2006
I paid 109 for the Wing Dragon 3 thinking I was getting a great deal. I mis understood. I guess the Wing Dragon 4 would have been a LOT more costly.. OH well. Maybe in time I can use the Rudder servo and add ailerions, IF I need to. I may just allow the kids to learn on the Wing Dragon 3 and let them advance to the Swift.. The Swift with it's ailerons can make tight landings. With the added nose wieght it flies a LOT better than right out of the box..
Wing Dragon? Skyshark Electric Plane Talk 27 Jun 09, 2009 12:57 PM
Question wing dragon?? PCola-Flyer Parkflyers 11 Jan 25, 2008 01:02 AM
Wing Dragon Vs Wingo Lastgoodguy Electric Plane Talk 4 May 10, 2004 03:42 AM
Wing Dragon excellent first E plane randall1959 Beginner Training Area (Aircraft-Electric) 21 Feb 08, 2004 06:52 PM
New Pusher "Wing Dragon" burdgeb Parkflyers 6 Oct 21, 2003 05:02 PM
