Old Nov 10, 2005, 12:12 PM
El Cajon, CA, USA
Joined Feb 2001
LVC on Phoenix 10
Hello,
I'm probablly doing something wrong and maybe you can provide some insight.
I cannot get the LVC on my phoenix 10 to kick in. I've set the voltage for 9.5, 9.3 and 9.0 and it still easily goes down to 8.8 and even sometimes 8.4. I vary the throttle (I think I remember that having something to do with it too). I also tried to use the older ESC software (the non-beta version).
Any ideas?
Munch is offline Find More Posts by Munch
Old Nov 10, 2005, 01:27 PM
"Each Day Is A Lesson"
diver don's Avatar
Goldsboro, NC
Joined May 2004
What kind of cut-off are you useing/ Hard or soft?
dd
diver don is offline Find More Posts by diver don
Old Nov 10, 2005, 01:39 PM
El Cajon, CA, USA
Joined Feb 2001
soft cutoff.
You can usually tell because the power lowers slightly and the sound the motor makes (pitch) changes alot.
Plus on the watt meter the volts seems to stay right around the programmed cutoff (dipping slightly below but not much).
Old Nov 10, 2005, 02:08 PM
diver don's Avatar
Goldsboro, NC
Joined May 2004
My thought was that it was going into 'soft cut-off" but you sound like your on top of that.
I'd call the CC boys and see what they have to say.
You have done everything I would have.
Good Luck,
DD
Old Nov 10, 2005, 02:28 PM
El Cajon, CA, USA
Joined Feb 2001
Thanks for the info Don.
Just to fill in some blanks.
I'm running a Fengau motor on an IPS A drive gerabox
3s Gen 2 TP 480's and a prolite 480 pack.
I was actually suprised the prolite pack dropped as much voltage under load as it did. The 2000 and 2100 prolite packs don't drop voltage nearly as much.
Discussion Cutoff voltage on phoenix 10 Terry Rigden Castle Creations 0 Apr 12, 2007 02:19 PM
Phoenix 10 & Razor V2 in Governor Mode on Heli Xnaron Micro Helis 5 Feb 27, 2004 02:59 PM
best deal on a phoenix 10 stealthy Electric Plane Talk 3 Feb 26, 2004 02:36 PM
Help with Thottle Setting on CC Phoenix-10 Brill 1 Power Systems 2 Dec 08, 2003 01:03 AM
Problems with Phoenix 10 and Outrunner motor on 3 lipo cells erashby Castle Creations 4 Jun 29, 2003 06:32 AM
