Old Mar 15, 2015, 03:51 PM
Joined Nov 2014
Question
benefits of using Vector airspeed sensor
Hello!
Already using Vector flight controller, very happy with it. Now I am planning to install Vector airspeed sensor.
What benefits will I have besides airspeed indication?
Can I teach Vector to use airspeed as minimal RTH speed?
What fixed wing flight modes would become more precise if Vector airspeed sensor is used? For example if in 2DH the model flights with strong side wind, will using airspeed sensor improves course hold?
Thank you very much for your inputs!
Sincerely,
Andriy
andriyco is offline Find More Posts by andriyco
Old Mar 16, 2015, 08:28 AM
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Hello,
Yes, you can specify airspeed instead of ground speed for certain calculations in the Vector setup such as RTH speed etc. The main benefit is that you can set an airspeed for RTH etc which will help ensure that your airframe will not stall in various wind conditions.
Regards, John
JohnET is offline Find More Posts by JohnET
Site Sponsor
Old Mar 17, 2015, 02:13 AM
Joined Nov 2014
Ok, thank you, John.
Could you please tell which check box should I mark in order to tell Vector that it must use airspeed during RTH? I found check box in advanced OSD settings, but don't want to make mistake.
And my other question. Does airspeed sensor improves 2DH?
Old Mar 18, 2015, 07:39 AM
JohnET's Avatar
Joined Apr 2013
Hello,
You can select to use the pitot for the ladder/RTH in the stick menu and select Calculate True Airspeed on the Compass and Sensor Setup page.
It can help with 2DH if there is significant wind.
Regards, John
Site Sponsor
Found Trade Vector XT60 Current Sensor for wire version relay700 FPV Equipment (FS/W) 0 Dec 23, 2014 01:31 PM
Discussion No Receiver Voltage, Vector Current Sensor is in place Jeausus Bolt Eagle Tree Systems 2 Oct 30, 2014 09:24 AM
Discussion When will Tower Hobbies get Vector air speed sensors garris2 Eagle Tree Systems 1 Jul 20, 2014 07:48 AM
Discussion Vector current sensor crazy readout bandito66 Eagle Tree Systems 2 Jul 15, 2014 09:34 AM
Discussion Benefits of Using PPM? What am I Missing? wannabe FPV Equipment 4 Feb 06, 2014 06:02 PM
