Old Mar 14, 2015, 06:03 PM
Joined Jul 2014
Max battery charge size.
Hi
I have a 4s battery. 8000mah. My charger will" only go up to 7000mah. I believe it will still fill the battery it will just take a it longer. Ami correct?
Larrythelathe is offline Find More Posts by Larrythelathe
Old Mar 14, 2015, 07:51 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Yes
hoppy is offline Find More Posts by hoppy
Old Mar 15, 2015, 04:07 AM
Staffs, UK
Joined Nov 2003
If you mean the charger has a maximum charge rate of 7A/7000mA (no "h") then yes.
If you mean the charger has a capacity cut-off of 7000mAh then no. You would need to charge twice to get an 8000mAh battery full.
Steve
slipstick is online now Find More Posts by slipstick
Old Mar 15, 2015, 06:00 AM
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Providing you're discharging your Lipo to the recommended 80% discharge or less, then a 7000mAh limit on your charger will be plenty. i.e 80% of 8000mAh = 6400mAh.
GordonTarling is offline Find More Posts by GordonTarling
Question Heli-Max 230si Battery Charging N410DC Multirotor Talk 1 Sep 09, 2014 12:04 PM
Discussion What size battery to charge with? GarryOgilvie Batteries and Chargers 10 Sep 04, 2014 10:06 AM
Discussion Can you charge 4ea 4000 mAh batteries on an 8A max charger? Maj.Duty Batteries and Chargers 3 Aug 29, 2014 10:15 PM
Discussion Battery size and storage charge RSTEARMAN Batteries and Chargers 5 Mar 03, 2014 12:11 AM
Discussion Cellpro 10S - Max Size Lipo to Charge through just Balance Taps? boiko FMA Direct 2 Sep 05, 2012 05:30 PM
