Old Feb 15, 2014, 09:42 AM
ClmPro's Avatar
Croatia
Joined Jan 2013
New Product
New composite pod #125
We are presenting you our new product, composite Pod / E-Pod #125
Pod is entirely made of fiber glass and carbon, it is very light and strong. 2.4 GHz friendly.
Pylon is for AG series airfoil. Pylon is thin and carefully engineered to reduce interference drag.
Dimensions of Pylon are 136x57mm (5.35"x2.24"). It is designed so the wing is easily attachable from below. Dihedral is 2.5 on each side.
Pylon is 136 mm (5.35") long, so wings up to 220 mm (8.66") depth but even more can be mounted.
Canopy is designed so there is enough space to easily manipulate with all components in the pod, allowing the battery to be inserted and connected easily, improving usability on the field.
Supplied with a removable carbon canopy.
Pod is reinforced with carbon on strategic spots which gives it more strength.
NOTE: This Pod is designed so that you can make an electro version. Since the nose is quite reinforced, it is only neccessary to cut the nose on specified length, put firewall and you get a diameter of 30 to 36 mm for a spinner. (look at attached pdf)
This Pod is suitable for wingspan up to 3 meter (118.11"). Ideal for home builder, it can be used as replacement pod for Bubble Dancer.
The final color is white - gelcoat, resistant to UV rays.
Length: 575 mm (22.637")
Wing depth: 220 mm (8.661")
Profile: AG Series
Boom diameter: 23 mm (0.905 in)
Spinner diameter: 30 - 36 mm (1.181"-1.417")
Dihedral angle of: 2.5
Weight: 105 g (3.70 oz)
For more details and pictures visit our website: http://clm-pro.com/fuselage-pod-125
ClmPro is offline Find More Posts by ClmPro
Site Sponsor
For Sale Composite Pod #125, new in our offer. ClmPro Aircraft - Sailplanes (FS/W) 0 Feb 09, 2014 10:15 AM
For Sale Composite Pods and E-Pods for sale, 2.4GHz friendly, with booms and V-mounts ClmPro Aircraft - Sailplanes (FS/W) 0 Oct 17, 2013 07:51 AM
For Sale 15% off on Composite Pods and E-Pods, 20% off for fuselage pod sets ClmPro Aircraft - Sailplanes (FS/W) 0 Sep 24, 2013 09:45 AM
New Product New composite E-Pod #122 ClmPro CLM Pro 0 Mar 23, 2013 10:02 AM
For Sale NEW composite electro-pod #122 ClmPro Aircraft - Sailplanes (FS/W) 4 Mar 11, 2013 08:25 AM
