Old Feb 22, 2015, 02:03 AM
ruppwf's Avatar
Germany, NDS, Wolfenbüttel
Joined Dec 2011
Originally Posted by MAMBA2200 View Post
Cant really tell where that is i can see the spot for the servo wire but cannot see if its front or back
This photo is from the bottom. The tracing line is the dividing line between the wing and fuselage. I add a photo from thr other side.
ruppwf is offline Find More Posts by ruppwf
Old Feb 22, 2015, 06:54 AM
Love To Fly
MAMBA2200's Avatar
United States, TN, Dandridge
Joined Mar 2013
Ok i see what your saying now thanks allot
MAMBA2200 is online now Find More Posts by MAMBA2200
Old Mar 19, 2015, 04:24 AM
prepps's Avatar
Sweden, Halland County, Varberg
Joined May 2013
Hi all,just ordered this kit yesterday and need help from the experts.
Will be running it on 4s 1600mah nanotech,can't remember the c-rating,at work right now,and a 60amp turnigy plush esc.
What would be the best motor and prop combo for speed?
And do i need a new propadapter?
I would prefer ordering from hobbyking for this.
prepps is online now Find More Posts by prepps
Old Mar 19, 2015, 04:42 PM
stwilkie's Avatar
UK
Joined Oct 2003
Luckily for you I test flew my radjet this morning, so the info is fresh in ma head
I chose the 2836 3000kv ntm motor, running on 4s 1000's (had them in the box) and a plush 60. First i tried the 5.5x5.5 apc pusher prop, watt meter said 79 amps which is about 20 too many for the motor, so then i ran on the 4.7x4.7 graupner camspeed prop, this gave me a max amps of 67, so I keep the full throttle to short bursts and we have a ball game.
Mine was the kit version so I put a 5mm carbon tube routed into the underside, with 4 spacers on the motor mount the model balances with the pack at the front of the bay.
Speed was great and sounded good as well, packs didnt last too long so over the next few weeks I will look at upgrading to something in the 1500-1800 range.
stwilkie is offline Find More Posts by stwilkie
Old Mar 20, 2015, 01:47 AM
prepps's Avatar
Joined May 2013
Thanks for the info,im thinking of using the 2836 2350 motor to start with and add some carbon to the wings.
Old Mar 22, 2015, 01:53 AM
Joined May 2010
Looks great...i have that same motor in zeta blaze which is an ultra radjet and its a beast with 4s 1800 40c 5x4 apc that was a 6x4,,, i use a 70 amp du=ertrum esc which is same as hobbywing...If you like 4s then go with 1600 to 1800 40c y0u will love it... you are going be in 115-120 mph at WOT...
hate2crash is offline Find More Posts by hate2crash
Old Mar 22, 2015, 06:34 AM
stwilkie's Avatar
UK
Joined Oct 2003
I ordered some 4s1600's they should be here midweek, am just stripping down a new radjet kit to paint for a friend will post some pics as i work on it this week.
Old Yesterday, 10:59 AM
Spring? Ever?
BWX_'s Avatar
United States, NY, Big Flats
Joined Nov 2013
Is there a big, "official" RadJet Ultra thread somewhere? Having a hard time finding it if there is one.
BWX_ is offline Find More Posts by BWX_
Old Yesterday, 02:59 PM
prepps's Avatar
Joined May 2013
Found this one. http://www.rcgroups.com/forums/showthread.php?t=2029519
Old Yesterday, 05:17 PM
Spring? Ever?
BWX_'s Avatar
Joined Nov 2013
Thanks. Yeah I saw that, I guess I thought there would be a bigger one. Oh well!
Old Today, 11:03 AM
Switzerland, VD, Lausanne
Joined Apr 2014
Hello!
I finally managed to bring my heavy Radjet in the air! The setup is a 3s with 240W motor-prop combo, with a 2200 mAh battery. It's quite heavy and the CoG positioning required some modifications.
It also has a FPV camera with a 180° pan servo, a video TX, but also the DragonOSDv2+ with its GPS. It's a tiny OSD with RTH autopilot, and I thought that it would be fine. However I needed some help for the hand launch, because with this weight I need almost full throttle, and this is dodgy. So I added a separate flight stabilizer NX3, it has an attitude hold mode, which is the mode I use for take off. It became easy!
However I didn't manage to set the autopilot correctly up. While it was a breeze in a plane like the Bixler, for the Radjet some correct settings are barely able to change the plane's heading. This is inherent to the fact that his OSD doesn't know the attitude of the plane, so he manages the heading by short corrections on the ailerons, which are too slight to change the heading. And if I increase the gains too much, the Radjet simply banks over.
So I'm changing the OSD and I'll go with a tiny APM implementation (a Micro HKPilot). It shouldn't be heavier than the Dragon OSD. And I'll be able to get rid of the NX3 stabilizer as this function may be taken directly from the APM.
I'll let you know of the success of the operation, and maybe I'll post some photos too
BuBu2 is offline Find More Posts by BuBu2
Contest Habu 32 Speed Contest Stock Class Habu Burners 7s 132.6 mph keithtsr Electric Ducted Fan Jet Talk 2081 Mar 07, 2015 01:16 AM
Discussion RadJet from the KING! vettster Foamy EDFs 1 Jun 01, 2014 06:00 PM
Help! New ViperJet From Hobby King dviperjet Electric Ducted Fan Jet Talk 20 Sep 30, 2011 07:04 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
