Old May 26, 2010, 11:26 AM
UK
Joined Oct 2006
Heli Motor On Wing?
I have an ESKY Belt CP with brushless main motor and was wondering if i could mount it to one of my flying wings (Combatwings XR)?
Any idea if the Motor/ESC/LiPo would have enough rpm etc? Details of the parts are below...
ESC
http://www.heliguy.com/Electric-RC-H.../EK1-0350-ESC/
Motor
http://www.heliguy.com/Electric-RC-H...ushless-Motor/
Battery
http://www.heliguy.com/Electric-RC-H...)-2100mAh-20C/
Shifty is offline Find More Posts by Shifty
Old May 26, 2010, 08:12 PM
meshyx's Avatar
Norway
Joined Feb 2010
I'm sure it'll fly You'll need to get the right propeller though.
I have been playing around with a 3000KV 25 gram motor, and I believe it drew over 20 amps with a 4.5 x 4.5 prop. I am amazed it's surviving that amp draw You'll want an even smaller prop. A 4.1x4.1 could be a good place to start, but I'd recommend you use a wattmeter to check that you're not frying the ESC. Remember that small props that spin fast generate a thin but fast airflow, so the wing might not have a lot of acceleration/power, but a high top speed.
I have several wings, and I'm most happy with the one that has a 50 gram motor around 1800KV turning a 7x6 prop on 3S. Lots of push, easy vertical climbs and plenty of speed.
meshyx is online now Find More Posts by meshyx
Discussion Cons to 500 motor on 450 heli? primer Mini Helis 6 Feb 19, 2010 03:27 PM
Discussion Two 2.4Ghz RX on same heli / Two 900Mhz Vid TX on same heli daltron FPV Talk 3 Dec 02, 2009 07:00 PM
For Sale 22 inch EPP wing Kit w/3000kv, 24 gm brushless motor, APC Prop, can be FAST, ON SALE sylair Aircraft - Electric - Airplanes (FS/W) 2 Nov 27, 2009 04:14 PM
Discussion motor mount on glider wing Ruud_NL Sailplane Talk 3 Sep 22, 2009 03:39 PM
How to silence the motor on rear mounted motor on a flying wing? soholingo Flying Wings 21 Jul 24, 2004 06:44 AM
