Old Feb 26, 2008, 09:05 AM
Joined Apr 2007
Question
Why Did It Just Stop ????????
I have a trex 450 with a JGF 450th motor. I attempted to go flying the other day and the motor just sat there !!! No humm, no buzz, no nothing. However all the servos were behaving normally. I figure that either the motor or the speed controller went south on me, but which one?
Can one of you knowledgeable pilots tell me how I can determine whether my problem is a bad motor or bad speed controller ?
(Don't know what I'd do without this forum !!!!!!!!)
Thanks in advance.
Bob Morris
swflybob is offline Find More Posts by swflybob
Old Feb 26, 2008, 09:08 AM
Inverted is where it's at
MiniCwik's Avatar
New Baltimore, MI
Joined Aug 2007
I had a similar issue, it was my motor that had gone bad. I tested it by swapping in another motor and the new motor beeped and the old one did not.
MiniCwik is offline Find More Posts by MiniCwik
Old Feb 26, 2008, 10:47 AM
crash. rebuild. repeat
Fairfield CA, USA
Joined Mar 2005
Are you sure the connections are good between the esc and the motor? With the motors i've blown, you can usually tell due to the smoke coming out of the components.
heli_newbie is offline Find More Posts by heli_newbie
Old Feb 26, 2008, 12:44 PM
Too dumb to upload an avatar.
chrise2's Avatar
On the LIRR somewhere
Joined Jan 2007
Did the ESC go beep beep or whatever it normally does when you power up? I had that problem and it was a bum solder joint between my battery and ESC. All my components worked because I had a BEC that went straight to the battery and that connection didn't fail. Check all the connections between the motor and ESC and between the ESC and battery.
chrise2 is offline Find More Posts by chrise2
Old Feb 27, 2008, 04:47 PM
Joined Apr 2007
Thanks for the info. Finally bit the bullet and bought a new speed controller. That solved the problem.
Bob Morris
Discussion Why did Great Planes stop making the Fokker Dr1? arukum17 Fuel Plane Talk 5 Dec 30, 2005 06:38 AM
I just got 12:15 hovering on my NIMH Blade stock pack, umm why did I need a LiPo? docprego Micro Helis 15 Sep 15, 2005 11:22 PM
Question Why did my motor stop? Wade Oh Power Systems 5 Oct 01, 2004 06:31 PM
What did I just say? flyfalcons Life, The Universe, and Politics 2 Apr 07, 2002 10:01 PM
why did it crash? Richard Electric Plane Talk 1 May 13, 2001 08:49 PM
