Old Jan 21, 2010, 11:17 AM
Joined Dec 2009
Why do CP helicopters fly better in the wind?
What about the design works better in the wind? Is it only better in idle up
mode it is it always better?
jedi391 is offline Find More Posts by jedi391
Old Jan 21, 2010, 12:39 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
The increased head speed has a lot to do with it, but also the fact that you can use negative pitch without reducing the head speed also helps.
1320fastback is offline Find More Posts by 1320fastback
Old Jan 21, 2010, 12:44 PM
Joined Sep 2004
It's only in idle-up that they do well in wind. If you catch a gust and the helicopter shoots up, you'll end up dangerously cutting rpms trying to get it down in non-idle-up-mode, which can easily result in a crash.
edfardos is offline Find More Posts by edfardos
Old Jan 23, 2010, 11:45 PM
United States, NJ, Manville
Joined May 2006
edfaros that is wrong and only happens when the throttle and pitch curve is set up wrong in normal non-idle up mode....Any proper setup should have neg pitch starting at less than half stick....At half stick the plades should have 0 pitch so the switch from normal to idle up should be seamless with no jumping....
skizziks is offline Find More Posts by skizziks
Discussion Noob question: Why do cp's fly better in wind again? conezone Electric Heli Talk 9 Oct 28, 2009 01:47 PM
Discussion why CPs handles better than FPs in the wind? Discusman Micro Helis 35 Oct 02, 2006 01:01 PM
Question why do americans fly only Corona when the LMH110 is better ? Kraeuterbutter Electric Heli Talk 23 Nov 26, 2004 11:15 PM
Question My SS can't take any wind...any mods for this plane to make it fly better in wind? Picoflyer Aerial Photography 19 Oct 06, 2004 02:05 AM
Question Why? Why a 0.2 gram butterfly able to fly in strong head wind? Why? Ming Foamies (Kits) 8 Nov 12, 2003 08:48 PM
