Old Apr 18, 2009, 07:58 PM
Connecticut, USA
Joined Oct 2008
Problem with my Spectrum??
Hey Guys,
So I was finishing up my Funder and Lightning and I set up my Spectrum DX6i for dual aileron servos. Today I finally got to final assembly and when I got everything wired and hooked up the ailerons were working the wrong way...no problem I thought...scrolled down to aileron servo reverse and clicked the appropriate box and bango...... the servo that was plugged into the aileron port of the receiver did indeed reverse but the servo in the aux port did not. Worse still, there is no provision in the radio to reverse the aux channel. Well after playing around for an hour I made a y connector out of two short servo extensions and from what I have read I think I could do some sillyness like create a mix with another channel? but I was disappointed that Spectrum would not program the aux channel to slave with the aileron channel when dual ailerons are selected.
or........did I miss something????
Peace
Paul
Wynterhawk is offline Find More Posts by Wynterhawk
Old Apr 18, 2009, 08:21 PM
Yummy cheese
enduro_man996's Avatar
Earth
Joined Mar 2009
Not sure with the DX6... But my DX7 the aux on the (Rx) is my Flap channel (Tx)... That I can reverse... and use as flapperons... however, I have found that some recievers do not support flapperons. I have tried 5 different types of spektrum recievers and the AR500 (I believe is the one) that does not support flapperons... it is (the aux) just a reverse signal from other aileron channel... the same as a Y connection.
Do you have a flaps channel on the Tx? that might be the difference?
enduro_man996 is offline Find More Posts by enduro_man996
Old Apr 18, 2009, 08:46 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
The monitor screen shows Ch 6 as the Aux and left aileron as Aux channel. It's got to be the flap channel like was said.
See p38 and 45.
hoppy is offline Find More Posts by hoppy
Old Apr 18, 2009, 10:19 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Why not just swap channels 1 & 6???
Gene Bond is offline Find More Posts by Gene Bond
Old Apr 18, 2009, 11:17 PM
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
LOL! Yeah, that would work too. The guys are right though. Reverse the FLAP channel and you're good to go.
kendall
tuppertn is offline Find More Posts by tuppertn
Old Apr 19, 2009, 07:13 AM
Connecticut, USA
Joined Oct 2008
Thanks for the replies guys I will try the flaps channel and see if that works.
Peace
Paul
Old Apr 26, 2009, 08:20 AM
Someone is going to get wet...
mudman1959's Avatar
The Mitt
Joined Oct 2007
Dx6I Programming...
Try this out... Worked for me on my Long EZ... http://www.rcgroups.com/forums/showp...2&postcount=35
mudman1959 is offline Find More Posts by mudman1959
Old Apr 26, 2009, 09:14 AM
Connecticut, USA
Joined Oct 2008
Mudman, Thanks! I actually printed those instructions out and pinned it to the wall in my shop!! LOL
Paul
Major glitching problem with my MiniMax using qualcomms on first flight! compuatic Parkflyers 3 Jul 03, 2002 09:59 AM
Got a problem with my astroflight 115d charger kushal_22 Foamies (Kits) 5 Apr 23, 2002 10:17 AM
I have a problem with my rotor head. ermit Electric Heli Talk 8 Apr 03, 2002 12:50 PM
Problem with my Exite mail tripster Aircraft - Electric - Airplanes (FS/W) 5 Dec 08, 2001 05:06 PM
Problem with my new Hitec Focus 3SSFM RCD markpsmith Electric Plane Talk 1 Aug 05, 2001 12:36 PM
