Old Feb 24, 2002, 08:23 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
Results of ailerions on undercambered slow fly wing ??
I was wondering if it was a bad idea to add ailerions to a undercambered slow fly wing? The model is the robbe bucker jungmiester. 30" W.S. sp300 motor designed for rudder & elevator control.
Id like to be able to do rolls with her, but if its inverted capabilities are bad because of the wing profile, I will scrape the idea.
Thanks before hand.
GiantScale is offline Find More Posts by GiantScale
Old Feb 24, 2002, 10:53 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Can't say for sure about the Jungmeister but I have a Robbe Stearman PT-17 that is kinda similar. I added ailerons to mine and it flies well. Will fly okay without using the rudder but the turns are prettier when coordinated. Am using the HL Acro 350 drive (with the 300 motor)
It loops and rolls great but when in inverted flight does lose a bit of altitude.
I removed almost all the dihedral and added fishing line flying wires to mine.
The only problem I've had is the styro fuse seems a little weak and I have two cracks in it. One from a landing when the LVC caught me by surprise and the other from a last second pullup/save from a screaming 45 degree inverted dive after a failed roll.
check out
my Stearman
Basketcase is offline Find More Posts by Basketcase
Discussion slow fly wing ricardo_bh Flying Wings 3 Dec 21, 2006 03:49 AM
Sold Mountain Models Dandy W/Slow Fly wing Norm66 Aircraft - Electric - Airplanes (FS/W) 0 Apr 26, 2006 08:45 AM
APC Cuts Price on "E" and Slow Fly props Azarr Electric Plane Talk 13 Jul 29, 2002 07:56 PM
Any advice on desiging a slow fly wing? slowflyer Foamies (Kits) 7 Mar 08, 2002 05:46 PM
Slow Flyer wing on a glider? tenover Parkflyers 0 Oct 09, 2001 11:54 PM
