Old Oct 10, 2014, 09:28 AM
United States, UT, Salt Lake City
Joined Jan 2014
Fuse/nose shape?
So i have a question for you guys concerning fuse/nose shape. i have noticed a few different styles in woodie nose shapes some come to a point like a boat bow , some are more of a blunt point shape, and others are really pointed. same goes for the fuse some stay true box shaped and other ether use thick balsa on the side and sand a radius into the fuse and other add triangle stringers and really sand the fuse. is there really that mush drag savings in all the extra work?
saltcitytattoo is online now Find More Posts by saltcitytattoo
Old Oct 10, 2014, 09:30 AM
salt:
The savings is in both weight and drag. My advice: round it out. Sandpaper is your friend when it comes to model airplanes.
For F3K, there is a minimum nose radius specified, for safety purposes.
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Oct 10, 2014, 04:34 PM
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Thanks Greg, right in time. had my foam pod almost ready to begin laminating, and now rounded the nose out like in the F3K specs. it was much pointier before as i took an airfoil as reference. The pod still looks decent to the eye.
found the minimum radius in the rules to be 7,5mm, and if you cut one quarter out of that circle it gives you the minimal surface for that curved nose piece.
I thought before there was also a minimal pod thickness to even out the competition, but i could not find anything about that, so i suppose as long as we respect the nose radius rule, we can build the rest of the pod as slim as we dare to go.
sp00fman is offline Find More Posts by sp00fman
Old Oct 10, 2014, 04:38 PM
United States, UT, Sandy
Joined May 2013
That minimum radious spec is actually quite a pointy nose
elkski is online now Find More Posts by elkski
Old Oct 10, 2014, 04:44 PM
Looptastic!
sp00fman's Avatar
Joined Nov 2009
Oops. for F3k it is 5mm. my bad. Shame i rounded my nose so much now ;/
Old Oct 10, 2014, 06:46 PM
No slope for richardo
Endless Sloper's Avatar
Seattle, WA
Joined Jun 2005
I think I need a picture. Is there a link somewhere for the rules on this? *Might* be making soe pods this winter...
Endless Sloper is online now Find More Posts by Endless Sloper
Old Oct 10, 2014, 08:28 PM
Looptastic!
sp00fman's Avatar
Joined Nov 2009
sure
http://www.f3k.nl/index.php?id=220&f...%202014def.pdf
Old Oct 11, 2014, 03:11 AM
Seattle, WA
Joined Jun 2005
Thanks man!
Wanted Taft viperjet fuse and nose gear indydrt33 Aircraft - Electric - Jets (FS/W) 1 Oct 13, 2014 11:08 PM
Found Alula fuse/nose bottom - wanted agarchitect Aircraft - Sailplanes (FS/W) 3 May 17, 2014 10:14 AM
Discussion Most aerodynamically efficient nose shape? I'm Rick James Modeling Science 7 Jan 10, 2006 06:18 PM
"V" Shaped Semi-Full Fuse - New Idea? FoamingInMI Foamies (Kits) 9 Aug 20, 2005 01:41 PM
Question Whats The Easyest and Fastest Way To Shape Hardwood Nose Blocks?? Mchone, Jake Sailplane Talk 44 Jul 23, 2005 09:41 AM
